steering column fitment cd5>cb7
    Hi everyone, i picked up a nice leather bound steering wheel from a wrecked CD5 sedan and am trying to install it in my 92 coupe , both cars have SRS.. the steering wheels look exactly the same , the airbags are also exactly the same and the plug matches etc, however the wheel will not fit, the splines seem to be different or something as it wont mount in properly.
    i have done some research and have figured the spline is the issue.. i really want this wheel to fit so im thinking to just go back to the wrecked CD5 take the steering column out and then fit it into my car?
    so yeh question is does anyone know if the steering column from a 95 CD5 is a direct fit to the 92 coupe? if im having issues up the top with the spline going from cd5>cb7 will there be fitment issues at the bottom where it meets the steering rack?
    if anyone could spare some info id really appreciate it!
    Yes, this column is a popular swap for those wanting to swap to the newer Honda steering wheels with the different spline size. I would recommend slotting the smooth-head screws that hold the ignition cylinder in place in order to unscrew them. Then you can reuse them to put the CB7 ignition cylinder on the CD column.
      Thankyou so much for your help, and yes slotting those screws is a great idea! so with the cd5 column it should mount up directly to the steering rack on my cb7? im hoping theres no fitment issues with it cos its a real pain taking these columns in and out! haha
        Yes, the CD column will fit the same as your CB column. You may need the collar that joins the column to the steering rack splines. I cannot remember if its needed, but it may fit the end of the CD column better.
          Selling is not allowed in the beginner forums.
          The offending posts were only deleted, do it again and you get to sit out for a while (if not forever).
            Im doing this swap tomorrow so ill try to take picturs if i can remember to bring my camera
              Jarrett and I found out tonight that the 90-91 steering column is different than the 92-93.
              Its a DIRECT SWAP if the cd5 column is going into a 92-93 cb7. Your good to go...unlike me lol
                I took lots of pictures, so we'll probably throw them into a DIY later today.
