if its a wire depending on the brand it should ether say on a tag on the wire or in the manual that comes with it. some indash screens have a bypass on them tho. what brand are you gettng?
Install In Dash Tv-same As Regular?
i have an alpine in-dash tv flip out and the e-brake wire for mine is in the harness itself. I want to bypass it as well and tried grounding it but it didnt work. Im not sure if i did it right or not. I grounded it with the same black ground wire from the harness. Do you guys know another way to ground it or how i can bypass it because im planning on getting an indash dvd player to go with it soon.
listen you may have a flip out that has like a giro in it..what that it is that unlike other flip outs that you can ground; well this one you cant because it senses that your car is moving..which also means your SCREWED!...if not then it could be that your not grounding it out right but like everyone else..i am not responsible if the cops get you and hand you a very nice ticket or even suspend your licence for wreckless driving or even revoc it..so have fun with that one.
