Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 03-24-2018, 10:17 PM   #1
'93CB7Ex
my k24 swap...
is running good for once. still have a couple things to handle, but it runs good and gets 27 mpg on the highway with only a basemap.
COUPE K24
Old 03-24-2018, 11:18 PM   #2
wtfisafleek
This is awesome man! How long did it take you and what more do you have to complete?
My '91 LX build. Bought September 2017.
http://www.cb7tuner.com/vbb/showthread.php?t=209871
Old 03-25-2018, 07:41 AM   #3
Raf99
How does it feel compared to a H22?
Old 03-25-2018, 10:50 PM   #4
illinois_erik
thats cool, but i hope you addressed the problematic timing chain tensioner issue before ploppin her in seems to be the largest bane of the K series in that displacement.
https://skunk2.com/engine/support-pa...0-05-0002.html
https://www.hybrid-racing.com/produc...series-engines
Old 03-26-2018, 08:24 PM   #5
'93CB7Ex
thanks! just clean up some wiring, get my ecu fixed, and put the interior back together.
right now, my ecu isnt commanding the VTC to work. i ordered another ecu and will have to get the kpro board swapped in. but it drives nice. has a good power band and sounds awesome up top.
nah i just took the stock engine and put it in. mine has around 100k so it will probably need a chain soon anyway.
COUPE K24
Old 03-27-2018, 09:53 AM   #6
Bunta
Bunta is cool... so far.
If I ever manage to blow up my H22 this is the next engine going in, looks to proper in there. I'll bet when you get all of the electrical/ECU issues sorted out it'll be that much more of a blast to drive. Did you have to get a custom header or are there off the shelf options out there for K24 swapped CB7's?
Old 03-27-2018, 07:04 PM   #7
'93CB7Ex
yea i got my new (used) ecu last night in the mail. i tried 2 different headers before i found this one to work. im running the ktuned budget swap header. clearance in the back near the subframe and intermediate shaft is almost none existent. this works good though.
COUPE K24
Old 03-27-2018, 07:05 PM   #8
illinois_erik
Be careful as its oil pressure operated, keep the levels up and run whats on the oil cap, Otherwise itll be new head time from pistons kissing valves
I think there was a TSB for the K24's
https://www-odi.nhtsa.dot.gov/acms/c...41669-6712.pdf
http://www.superstreetonline.com/how...ies-tensioner/
http://techinfo.honda.com/Rjanisis/pubs/SB/B12-042.PDF
Old 03-27-2018, 07:57 PM   #9
'93CB7Ex
that honda tsb is pretty wild lol. mine is an older tsx (1g). no oil issues other than a cracked valve cover at this time.
COUPE K24
Old 03-28-2018, 10:09 AM   #10
Raf99
I recently learned that the K series in a cb7 hangs low / oil pan hangs low.
Old 03-28-2018, 09:50 PM   #11
'93CB7Ex
mine is kinda low i guess, but my car isnt lowered too much. maybe 1.25/50"
COUPE K24
Old 03-29-2018, 08:39 AM   #12
Rilas
Could you possibly take a picture of how your pan is hanging? Thanks!
Old 03-29-2018, 08:36 PM   #13
'93CB7Ex
yea maybe this weekend.
COUPE K24
Old 04-09-2018, 08:48 AM   #14
BreckAConner
BreckAConner is cool... so far.
What did you do for CV shafts?
BreckAConner is offline   Reply With Quote
Old 04-11-2018, 07:21 PM   #15
'93CB7Ex
i bought some "swap" axles. the passenger side didnt work out. used a 8g civic si ps axle. pretty sure it would perfect on the driver also.
COUPE K24
Old 04-11-2018, 09:57 PM   #16
sonikaccord
We should go for A beer run one day
Old 04-11-2018, 10:07 PM   #17
BreckAConner
Okay, that's good to know. Not sure if I would ever be able to do a K-Swap but if I didn't I was wondering what would work. I've seen aftermarket axles but they are $350 + for a pair.
Old 04-18-2018, 08:20 PM   #18
'93CB7Ex
yea i wasnt gonna pay that for axles.
ive been driving the car around for a while now. got my kpro back from upgrading to v4. been trying to tune it some on the street.
also side note: getting the air out of the cooling system is the hardest thing ive had to do with doing the whole swap.
COUPE K24
Old 06-18-2018, 01:59 PM   #19
G. Wiffington
Hey man, I just came across this thread again & I totally forgot about your K Build.
How is the setup going? It looks really good.
Old 09-28-2018, 09:57 PM   #20
Grumpys93
Bump. Give us updates!
~Nick~
Grumpys93 is online now   Reply With Quote
