Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Thread Tools Rating: Thread Rating: 89 votes, 5.00 average. Display Modes
Old 10-26-2006, 10:38 PM   #21
4CYLPOWER92
4CYLPOWER92 is cool... so far.
So I have a question and did the search with no luck. The MAP sensor on our cars is on the TB, but I read that the H22 TB there is no MAP sensor, but that on preludes its on the fire wall in a box. Do we need this box in order to have the MAP sensor? Doesn't the ECU check for that?
4CYLPOWER92 is offline   Reply With Quote
Old 10-26-2006, 10:52 PM   #22
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
where did you hear this from?
the map sensor in a CB is in that black plastic box near the fusebox w/ the vacuum lines runninig from it. most OBD-1 H22As will reuse that setup. OBD2 and some JDM motors came with a MAP mounted right to the top of the TB. you can wire the new map up in place of the old one, or you can find a way to make a vacuum nipple (could just use a diff TB that doesnt need modding).
the car doesnt really run without it hooked up
Old 10-27-2006, 12:43 AM   #23
blackcb7
Accord of the Month: May 2008
blackcb7 is cool... so far.
i have this on my jdm h22, i just left the sensor alone on top of the throttle body and just plugged the accord vacumm line to one of the nipples on the manifold, it runs fine, but would this affect my emmissions?
Members Ride
blackcb7 is offline   Reply With Quote
Old 10-27-2006, 12:48 AM   #24
4CYLPOWER92
Yeah nevermind guys. I was reading swap info and they were talking about the 5th gen Accord. Woops.
Old 10-27-2006, 12:50 AM   #25
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
im not sure if the nipple on the TB is really any different than the others, as they are all behind the throttle plate, and the diagrams dont show anything unique about it. so i guess it would work fine
Old 10-27-2006, 12:53 AM   #26
4CYLPOWER92
But I have a better question now.
I keep hearing (or reading) peoples threads on the Air Boost Valve saying it may help to pass emmisions. But in reading the manual all it says all it does is supply more air to the TB to help with startups. So how can that help with emmisions if it only functions during startups?
Old 10-27-2006, 01:44 AM   #27
GHOST 2.2
SoCal Regional Moderator /Accord of the Year
GHOST 2.2 seems to have made some friends!
i guess is supposed to make the intake manifold colder thus making more combustion. dont quote me on that i may be wrong.
GHOST 2.2 is offline   Reply With Quote
Old 03-17-2007, 12:46 AM   #28
10thcb7
Banned
10thcb7 may be a total jerk. It is very likely.
thread still invalid.
the pic i whack and me asking might change this.
Hey mod can you edit this thread by placing the info on pin removal here?
fix da link sheez
10thcb7 is offline   Reply With Quote
Old 04-21-2007, 01:21 PM   #29
areem57
areem57 is cool... so far.
So if im using a stock f22 tranny, do I use the stock accord half shaft?
areem57 is offline   Reply With Quote
Old 04-21-2007, 10:00 PM   #30
SMseagren83
Accord of the Month: October 2007
SMseagren83 is cool... so far.
Send a message via AIM to SMseagren83 Send a message via MSN to SMseagren83
yes use the accord half shaft.
F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
SMseagren83 is offline   Reply With Quote
Old 07-16-2007, 10:41 PM   #31
MR.PHIL
Contributing Member / AoM December 2007
MR.PHIL is cool... so far.
Unhappy No vtec Oil Presure Sensor for me
I Have a 97 Honda accord Sir H22a ,that unlike the picture bellow it doesn't have the Vtec oil Pressure Sensor .
My question is,Can anyone tell me how do i wire that up?i've search but came up with nothing .
I would appreciate the Help .
THANKS
-->751 whp @ 27psi <--...Midnight Tuning <----
MR.PHIL is offline   Reply With Quote
Old 07-17-2007, 02:16 PM   #32
BustedLX
BustedLX is cool... so far.
THANKS
If you don't have the sensor then there is nothing to wire up. Just wire in the Vtec solonoid, chip your OBD-1 ECU and program the rom to ignore the Vtec oil pressure sensor so that Vtec will work and you won't get a CEL.
BustedLX is offline   Reply With Quote
Old 07-17-2007, 05:10 PM   #33
MR.PHIL
thanks bro,but i already use an other one that has the oil pressure sensor and i ran the wires ( I'm assuming (still ok )
Old 07-17-2007, 07:31 PM   #34
NAiL05
CB7Tuner Member
Location: Dallas, Waco, And now SIUC for school I'm going worldwide bitches!!!
NAiL05 seems to have made some friends!
^^That will be fine.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
NAiL05 is offline   Reply With Quote
Old 07-17-2007, 11:20 PM   #35
cb9tuner
cb9tuner is cool... so far.
yea that happenend to me to mine didnt have one etheir I mine just had a screw in the location where its supposed to be
I just ended up getting a pressure switch I havent put it on but you should be just fine
cb9tuner is offline   Reply With Quote
Old 07-18-2007, 10:37 AM   #36
BustedLX
So you mean you have a Vtec engine in your car now and the pressure sensor is all wired up?
Well just leaving the plug there unconnected should be ok, you just have to program the rom to ignore that input and it'll work with no CEL.
If you have an OBD-1 H22A Vtec solonoid with pressure sensor I see no reason why you couldn't swap that aseembly for the OBD-2 one. Just get a new gasket/filter/striener and you'll be good to go.
Old 07-18-2007, 11:22 AM   #37
MR.PHIL
here's The thing,Mrx has already Chipped the p28 for me ,now he's back in J-ville
so i had to do something.
Old 07-18-2007, 03:10 PM   #38
BustedLX
So you're trying to resolve this without making any changes to the rom???
Old 07-18-2007, 06:37 PM   #39
MR.PHIL
no buddy,ecu was chip before the swap
Old 07-18-2007, 06:39 PM   #40
MR.PHIL
quick question,what if the pin slot already has a wire in it? do i remove it or just tap into it.
for example (Pin A17 is not empty ,should i just tap on it?
