Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Thread Tools Rating: Thread Rating: 89 votes, 5.00 average. Display Modes
Old 04-23-2008, 03:23 AM   #61
LinX
LinX is cool... so far.
for usdm, the fuel rail should be on the same side. Check your f22 and h22.
The dizzy should just be direct install if you have 92/93 cb7. Those are external already.
...adjust accordingly
LinX is offline   Reply With Quote
Old 04-23-2008, 05:14 PM   #62
accord2nr81
accord2nr81 is cool... so far.
Send a message via ICQ to accord2nr81 Send a message via AIM to accord2nr81 Send a message via Yahoo to accord2nr81
my h22 had the fuel rail hose on the wrong side and its usdm... 98 model though...luckaly i can use my aem fuel rail to solve this problem
f22 dizzy wont work the mounts are diff ... if you want to keep ext coil get a h23a obd1 plugs are the same and mounts the same
Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
Originally Posted by deevergote. View Post
But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
accord2nr81 is offline   Reply With Quote
Old 04-25-2008, 09:09 PM   #63
Night Wolf
Night Wolf seems to have made some friends!
Send a message via AIM to Night Wolf
^^^ what if the dizzy looks the same. like my CBs dizzy was external & my 97 H22 is too. it also has 2 plugs like my accords engine had. can I cut/splice it to the CB harness im using?
one new question=the H I have has injectors with 2 wires each. just like the accords. can I just splice the H's injector pigtails to the accords harness? & what about the risistor box the accords use for the injectors? do I leave it unplugged?
93 Accord LX Sedan (sold)-01 Civic LX Sedan (sold)-93 Accord EX Wagon (totaled)
93 Accord SE Sedan (sold)-95 Accord LX Wagon (CURRENT)-92 Accord EX Sedan (sold)
93 Accord SE Coupe (sold)-97 Accord SiR Wagon (CURRENT)-05 Impreza WRX Sedan-(CURRENT)
Night Wolf is offline   Reply With Quote
Old 04-25-2008, 09:16 PM   #64
texasvtak
Southern Regional Mudder Hater
texasvtak seems to have made some friends! texasvtak seems to have made some friends!
Send a message via AIM to texasvtak
Theres more than one sticky and youre still asking questions that have been very visibly answered in said stickies.
If you cant find an answer in this thread or http://www.cb7tuner.com/vbb/showthread.php?t=8873 then youre too drunk to read.
To-Do List for Today
Be Awesome
texasvtak is offline   Reply With Quote
Old 04-27-2008, 01:08 AM   #65
Night Wolf
^^^ not very helpful. I Ive read many topics & stickies. if I saw the answers to my questions I wouldnt be asking this.
now I got some more questions
1st...
what are these metal tubes for? they used to lead to a spot near the speed sensor on the auto tranny. theres also 2 hoses comming out of the radiator. what do I do with them all?
2nd...
I tryed doing the whole drill & tap thing to my lude 5psd tranny. then I tryed using a CB 5spd mount but the tranny sits too far foward! one of my cbs mount arm is right over where the CB tranny mount would be. theres just no way to use the CB7 mount with my lude 5spd tranny. so what OEM mount can I use? (my CB was once A/T btw)
3rd...
I read some where that I can use my CB7s fuel rail on my H22 with the H22 injectors. is this true? cuz the fuel rail that came with my H22 is on the drivers side instead of the pass side.
4th...
my H22s injectors have 2 wires each (just like my F22 did). so can I just use the the H22 injector pigtails & tap them to the F22 harness that I have installed on the H?
5th...
do I keep the fuel injector resistor if I use my H22 injectors? they have 2 wires each like the F22 did.
6th
I took a closer look at the H22s external dizzy. one plug has 2 wires just like the F22 external dizzy does. the other plug has 4. on the F22 this plug has 8.
so can I just cut & splice the F22 harnesses plugs onto the H22s dizzy plugs? or can I just swap out the interior components of the H22s external dizzy with the F22s external one??
these are the last things I need to get my CB up & runing again!
Old 08-08-2008, 05:36 PM   #66
CB7 Fanatic
CB7 Fanatic is cool... so far.
Send a message via AIM to CB7 Fanatic
Harness ?
I probably know the answer to this, but I have the wire harness for the h22. Can I just use this? Or do I have no choice but to modify the CB harness? Without having matched plug for plug, it looks like the Accord has more plugs.
CB7 Fanatic is offline   Reply With Quote
Old 08-08-2008, 05:38 PM   #67
1990Ex
1990Ex is cool... so far.
i think everything matches up on the stock harness, i could be wrong though
UNDERGROUND SOCIETY
NEW COUPE MEMBERS RIDE THREAD COMMING SOON
1990Ex is offline   Reply With Quote
Old 08-08-2008, 05:58 PM   #68
CB7 Fanatic
What do you mean "stock harness"? h22 stock harness or f22 stock harness? Like I said, it looks like there are additional plugs on the drivers side of the f22 harness that the h22 harness doesn't have. I haven't looked at it very closely though.
Old 08-21-2008, 05:42 PM   #69
CB7 Fanatic
Wiring Mess
OK. Unable to get an answer, I assume that I'll use the Accord harness on the H22 (and use parts of the H22 harness?). I know that there are many how-to's for the re-wiring. The problem is that none of them have pictures and the colors for the wires aren't matching up on my harness. Also, since everything I see says that you need the H22 harness, I assume that I will use parts from it. I haven't seen anything like "cut this connector off and attach this wire to this wire and that wire to that wire". What the hell?!? I'm very frustrated and desperately need to get this car started this weekend. Any help or links to existing threads would be greatly appreciated.
Old 08-21-2008, 07:19 PM   #70
MR.PHIL
Contributing Member / AoM December 2007
MR.PHIL is cool... so far.
YOU answered your own question
it's real easy bro,just follow that method
-->751 whp @ 27psi <--...Midnight Tuning <----
MR.PHIL is offline   Reply With Quote
Old 08-21-2008, 08:21 PM   #71
4CYLPOWER92
4CYLPOWER92 is cool... so far.
You really don't need any parts off the H22 harness, except the connectors for the AIB? the VTEC solenoid and pressure switch, etc.
Its all in the FAQ. Keep reading it till it starts to make sence. I read it at least 20 times before I did my swap.
4CYLPOWER92 is offline   Reply With Quote
Old 08-22-2008, 12:23 AM   #72
LinX
I can understand having some major questions going into this swap but believe me, if you read and search on this forum and hondatech you will have 99.9% of your questions answered if not all. Most of the answers are just common sense when you stop and think about them.
Old 10-23-2008, 01:51 AM   #73
R33cb7
R33cb7 is cool... so far.
Question Need Some H22A Swap Help!
Guys,
As some of you may know, some of the SOCAL guys hepled me install an H22A with Auto LSD into my CB. They did a great job helping me put it in, but now it's time to get it running. Here are some problems that I am running across:
1. Radiator fan is not comming on.
2. CEL is on
3. Idle is at about 2300 RPM's
Here's what I've got hooked up and what I can't figure out:
HOOKED UP:
1. VTEC Solenoid- Connected to Pin A4 on ECU.
2. Knock Sensor- Pin D3
CAN'T FIGURE OUT:
1. VTEC Pressure Switch: Supposed to go to Pin D6 on ECU, however there are 2 wires on that plug. Is one a ground?
2. Secondary Intake Solenoid: Supposed to connect black/yellow to swiched ignition, the other wire to Pin A10. WHERE THE FUCK IS THIS THING?
3. FPR Solenoid: WTF? Do I even have this? My Accord is an SE.
ITEMS THAT CAME OFF MY F22A6:
1. EGR Valve
2. Upper Radiator Hose Neck
3. Alternator
4. Fuel Rail/Pressure Regulator (AEM)
HEEEEEEEEELLLLLLLLLLLLPPPPPPPPPP!!!!!!!!!!!!!!!
If imitation is the best form of flattery............thanks for kissing my ass.
R33cb7 is offline   Reply With Quote
Old 10-23-2008, 06:40 PM   #74
NAiL05
CB7Tuner Member
Location: Dallas, Waco, And now SIUC for school I'm going worldwide bitches!!!
NAiL05 seems to have made some friends!
Make sure you dont have any plugs confused. Some people sometimes get the temp sensor confused with the EGR or something like that. Either way they look similar.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
NAiL05 is offline   Reply With Quote
Old 10-24-2008, 09:23 AM   #75
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
1. like nail said, people often confuse coolant temp sensor (aka radiator fan switch) plugs with other plugs nearby. double check that for the sensor on the t-stat housing is the green plug with black and blue wires. otherwise, are you sure you plugged the fans back in?
2. CEL is on - so pull the code, itll tell you what it means all on its own :P might even tell you which of the plugs you have mixed up with the fan switch lol
3. your throttle cable is probably too tight, try unhooking it from the rotor and start the car again. this was an issue with EX accords having a shorter cable...
1. vtec pressure switch - ground the second wire, just attach a ring terminal and hook it to the ground on the thermostat. it doesnt matter which wires of the two you use, it would work either way.
2. secondary intake solenoid = IAB = the black control box that makes the intake butterflies open. you might need to salvage this off the underside of your f22a6 intake manifold. but for the wiring one pin to the ECU, the other pin to +12v ignition (you can tap off a black/yellow wire on the distributor plug). you may not even have to wire this up on your own, it would actually still be part of your engine wiring harness... so you may be good to go already.
3. no you do not have an FPR solenoid, disregard this
good luck.
Originally Posted by R33cb7 View Post
Guys,
2. CEL is on
HOOKED UP:
CAN'T FIGURE OUT:
1. EGR Valve
3. Alternator
cp[mike] is online now   Reply With Quote
Old 10-25-2008, 09:29 PM   #76
R33cb7
Thanks Mike, I got it running fine now!
Old 07-14-2009, 12:22 PM   #77
jaykilla116
jaykilla116 is cool... so far.
i have a problem
i orderd a header and down pipe for a h22a1 and it does not fit i have a h22a jdm are the headers differnt or did they send me the wrong part
a person who looks at somthing and see it as waste is no person at all but he who see what it could be will suceed
jaykilla116 is offline   Reply With Quote
Old 07-14-2009, 08:54 PM   #78
4CYLPOWER92
It should definately fit.
Old 09-15-2009, 07:50 AM   #79
93JDMBeast
93JDMBeast is cool... so far.
Send a message via AIM to 93JDMBeast
Okay ?? about the A/C guys ? Ima just need to put the f22 bracket nd compressor on the h22 ok got it , but what about the belt ?? What belt should I use that will fit ?? Use the h22 one or f22 ??
93JDMBeast is offline   Reply With Quote
Old 09-15-2009, 07:53 AM   #80
accord2nr81
depends witch crank pulley you use. best way is to wrap a string around the both pulleys and get how many inches it is and then tell the parts store what you need....
