Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Thread Tools Rating: Thread Rating: 89 votes, 5.00 average. Display Modes
Old 09-15-2009, 08:03 AM   #81
93JDMBeast
93JDMBeast is cool... so far.
Send a message via AIM to 93JDMBeast
Originally Posted by accord2nr81 View Post
depends witch crank pulley you use. best way is to wrap a string around the both pulleys and get how many inches it is and then tell the parts store what you need....
like outside or on the block all together and use the string as nd belt to get the size of it ?
93JDMBeast is offline   Reply With Quote
Old 09-15-2009, 12:53 PM   #82
MR.PHIL
Contributing Member / AoM December 2007
MR.PHIL is cool... so far.
your f22 belt will fit,that what i used
-->751 whp @ 27psi <--...Midnight Tuning <----
MR.PHIL is offline   Reply With Quote
Old 09-30-2009, 02:07 PM   #83
93JDMBeast
"For the 5-Speed you will to use a 10x1.25mm tap to tap the two unused holes in the Prelude transmissions case. Before you can do this the holes need to be enlarged with an 11/32" drill bit... get a drill bit that is made to drill through metal! Remove the two studs from their old location, and install them in the location you just drilled and tapped. Then you can mount up the Accord's tranny mount on the Prelude transmission." OK , HOW ABOUT FROM AUTO GOIN 5SPEED H22 TRANNY SOME SAY GET THE 92-94 LUDE MOUNT , BUT WILL HAVE TO PUT A SPACER ON THE TIMING BELT MOUNT CUS IT WOULD BE UNEVEN CAN SOMEONE HELLP !
Old 10-23-2009, 10:58 PM   #84
drummersteve7
Boost Junkie Rehab!
drummersteve7 seems to have made some friends!
tensioner kit from IRP only $90!!!
True genuine Honda parts ladies and gents.
Cheaper than getting both tensioner adjusters from Honda alone!
Didn't know if anyone was using this but is a better way to get that auto to manual swap done! Tensioner Kit FTW!
Link to Tensioner Kit
MadLab Racing
Southern Maryland
drummersteve7 is offline   Reply With Quote
Old 10-24-2009, 02:21 PM   #85
illestatus
Accord of the Month: July, 2010
illestatus seems to have made some friends!
Send a message via AIM to illestatus
i need that
illestatus is offline   Reply With Quote
Old 01-16-2010, 04:18 AM   #86
rezist09
rezist09 is cool... so far.
this is good since ima be doing h22 auto swap
1992 Accord Cb7:
rezist09 is offline   Reply With Quote
Old 02-03-2010, 01:53 PM   #87
cb7pr
Southern Regional Moderator
cb7pr is cool... so far.
Cheaper if you eliminate balancer shaft belt, you avoid getting one of those adjusters.
'09 Mini Cooper S (R56)
cb7pr is offline   Reply With Quote
Old 03-30-2010, 08:51 AM   #88
drzcb7
drzcb7 is cool... so far.
yess about this what needs to be done??
drzcb7 is offline   Reply With Quote
Old 05-14-2011, 03:46 AM   #89
CyborgGT
CyborgGT is cool... so far.
^ Buy an auto-to-manual mount kiit from ESP?
Originally Posted by MR.PHIL View Post
Same Problem here,i also tapped it in the GREEN/WHITE wire to pin A7,and it still not shifting .
ANY UPDATES GUYS ?
Has anyone found a solution for us guys with auto trannies yet? My H will be ready to drop in real soon here.
Old 04-30-2012, 01:11 AM   #90
CyborgGT
^ For the sake of future readers not having to search around: the solution was to go to the TCU plugs. Cut the GRN/WHT and WHT/GRN wires or de-pin them from the TCU, then splice them together on the harness side (i.e. don't make a jumper from one TCU plug to the other). No running of wire from the shifter position switch to TCU pin A7. I think this really needs to be added to that section regarding using the automatic transmission and TCU.
Old 05-08-2012, 09:24 PM   #91
antonio7566
antonio7566 is cool... so far.
Hey guys just want to make sure I understand the following info. You need to swap over the front bracket From the f22 to the h22 engine in order to use the front torque mount? Thanks in advance.
antonio7566 is offline   Reply With Quote
Old 05-08-2012, 11:53 PM   #92
CyborgGT
That's what I did. Fits perfectly.
Old 05-09-2012, 01:08 AM   #93
antonio7566
Thank you sir, thanks for the input.
Old 06-01-2012, 08:59 PM   #94
CyborgGT
My next big move will be to get a manual coupe to move my H-swap and everything else over to. Is it just the ECU I need to worry about replacing with a manual one? I have ESP mounts on my auto setup, so of course I'll need the manual tranny mount to keep using them (using an Accord tranny, so no drilling/tapping yet); and I'll get an H22 p/s line since I want that system back in, as well as a new OE-spec clutch kit for a bit of preventative maintenance, but am I forgetting anything needed to get it driving?
Old 01-01-2013, 06:25 PM   #95
Straight Success
Straight Success is someone to admire Straight Success is someone to admire Straight Success is someone to admire
Removal / Installation ...
Can I swap the engine and transmission through the bottom of the car with it jacked up in the air for removal of the F and installation of the H, and if this way does work, will I have to remove the cross beam for this way to work?
The Lord watches over me!
Straight Success is offline   Reply With Quote
Old 01-02-2013, 08:43 AM   #96
toycar
toycar is very helpful toycar is very helpful toycar is very helpful
Ive never done that, but the entire cradle is installed that way so it can be done.
I pulled the front off the car and walked it out that way. Its really not that bad. Maybe 2 hours worth of bullshit for a really easy venue to handle shit.
Originally Posted by wed3k View Post
toycar is offline   Reply With Quote
Old 08-28-2013, 11:27 PM   #97
Mishakol129
Mishakol129 may have said something they shouldn't have...
Is there REALLY supposed to be an empty space in the plug for A17? Cause right where I THINK is A17 there is a pink and blue wire sticking out of
The only place where a blank space is that I believe is A17 is when I flip the entire diagram upside down so that what was on the right and the top is now on the left and on the bottom... I put my pin for the IAB's there but who knows if its the right one?
Car came with the A1 btw.
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Mishakol129 is offline   Reply With Quote
Old 12-15-2013, 05:51 PM   #98
sepulveda87
sepulveda87 is cool... so far.
I just swapped my accord tranny for a t2t4. It fits but the passenger tranny mount that I have (innovative mount for a cb7 w/a h22 swap) does not. The mount is "too short" to bolt up to the accord mount location. Basically the mount needs to be taller, well seems it needs to be. Does anyone have any insight?
sepulveda87 is offline   Reply With Quote
Old 12-16-2013, 06:41 AM   #99
sepulveda87
i found out that the passenger side t2t4 tranny mount is taller/longer than the h22 mount. well looks like im gonnna have to buy another mount.
Old 12-16-2013, 09:22 AM   #100
Jarrett
Was your car originally an automatic?
