So I drive a 96 ex v6, and I use to get about 285 miles to a tank of gas. Now I get about 200 and idk it all started about 2 months ago and my overdrive works and everything I even put fuel injector cleaner in it too same result does any body know why?
Bad MPG?!
It's probably your O2 sensor.
Yes, a Heated Oxygen Sensor (HO2S) can cause a gassy smell, but keep in mind that this may actually be a symptom not a cause. Visually inspect both HO2Ss. I use a 22mm closed end combination wrench to remove them, take the heat shield off first to get to the secondary (2°) HO2S. Look for any physical damage. Only buy Denso replacements.
On my car, the 2° HO2S is always the one that gets damaged when excessive unburnt fuel is dumped into the catalytic converter. The cat begins burning the excess gasoline and the high temps travel downstream and melt the 2° HO2S.
Let us know what you find.1997 Honda Accord EX-V6:
C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
MPZA - Electronically controlled 4-speed automatic, 1 reverse
~170 cu. in. / ~170 ft. lbs. / ~170 whp
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
With the gas smell you're probably running rich.
Originally posted by James Matteu View PostYes, a Heated Oxygen Sensor (HO2S) can cause a gassy smell, but keep in mind that this may actually be a symptom not a cause. Visually inspect both HO2Ss. I use a 22mm closed end combination wrench to remove them, take the heat shield off first to get to the secondary (2°) HO2S. Look for any physical damage. Only buy Denso replacements.
Originally posted by vietkid_2006 View PostWith the gas smell you're probably running rich.
Originally posted by Dmoney2499 View PostOk another quick question where is the O2 sensor so I can replace it?1997 Honda Accord EX-V6:
Originally posted by accordguy69 View Posti know this is off topic but quick question have u tried that tornado thing that kinda looks like a cheese grader lol it goes at the intake hose it like regulates the air flow there for giving you better gas milage. think it would work?? i just came across that nd i saw this thread.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
