3k RPM Idle and hard brake. Changed brake booster. Same Problem
    When the car is cold the car drives great, but when the car warms up the pedal gets harder and the wheels lock up and the idle jumps to 3000 RPM . I changed the brake booster and check valve and i still have the same issue. I bleed the brakes many times as well. I need your expertise. I dont know what to do.......
    PSN: DJ-dlatino
    My ride
    http://www.cb7tuner.com/vbb/showthread.php?t=140370
    The cause to the idle raising is a vacuum leak, whether it is the hoses, IM, or IACV.
    The brakes I have no idea, sorry man !
    Colombian CB7
    http://www.cb7tuner.com/vbb/showthre...3A+1992+accord
      The problem is clearly related to the the vacuum leak
      Maybe the hose has a leak in it?
      The booster runs off engine vacuum. When you rev the engine up the vacuum goes away and you lose power brakes. It is restored instantly when you let the engine go to idle
      A fun little experiment is to drive down the highway and give it alot of gas and try to work your brake pedal with the other foot
      after 2 or 3 brakes the pedal will get hard.
