HONDA ACCORD COUPE - Sale in 4/1990
HONDA ACCORD COUPE 2.0Si EXCLUSIVE
Specifications
Engine/Fuel
Engine Model F20A
Maximum Power 150ps(110kW)/6100rpm
Maximum Torque 19.0kg・m(186.3N・m)/5000rpm
Displacement 1997cc
Bore×Stroke 85.0mm×88.0mm
Compression Ratio 9.5
Fuel Tank Equipment 64L
Suspension
Minimum Turning Radius 5.5m
Tires Size 205/50R16
Drivetrain
Driving Wheel FF
Transmission 4AT
Gear_ratio
1st Gear 2.705
2nd Gear 1.464
3rd Gear 1.028
4th Gear 0.731
Reverse 2.047
Final Drive Gear Ratio 4.2
General Specification
Model: E-CB6
Dimension: 4680×1695×1375mm
Wheelbase: 2720mm
Tread front/rear: 1475/1480mm
Dimension(Interior): 1925×1340×1085mm
Weight: 1320kg
Body Type: Coupe
Doors: 2
Riding Capacity: 5
ORIGINAL ENGINE AND COLOR
TRUNK AMAZING FEATURE
STEERING ORIGINAL LOGO
ORIGINAL SEAT COLOR AND STYLE
ORIGINAL DASH BOARD AND PANEL INSTRUMENT
AFTER 23 YEARS INTERIOR DESIGN IS STILL UNCHANGED
THANK YOU FOR LOOKING
Specifications
Engine/Fuel
Engine Model F20A
Displacement 1997cc
Suspension
Drivetrain
Driving Wheel FF
Transmission 4AT
Gear_ratio
1st Gear 2.705
2nd Gear 1.464
3rd Gear 1.028
4th Gear 0.731
Reverse 2.047
Model: E-CB6
Wheelbase: 2720mm
Weight: 1320kg
Body Type: Coupe
Doors: 2
Riding Capacity: 5
