Help troubleshoot P28 ECU
    I'm sure that there's a thread around here that covers this, but I didn't see it in my search. If you could point me in the right direction it would be greatly appreciated.
    Okay, i was having a conversation with a friend of mine about his ECU..
    Originally posted by Friend
    I just got a p28 in trade that does not work. Its been chipped and socketed. I am trying to run a h22 with it as it has the h22 chip. When I plug it in and turn the key on the cel does not come on at 1st like it should and the car wont start. I am wondering of this can be fixed and what I can do to fix it as far as like remelting the solder on the board where the chips where added, that sort of thing.
    Originally posted by Me
    Have you opened it and looked inside yet? I would say that's the first step.. make sure all the solder points are in good shape, no leaking resistors.
    Every thing looks good inside.Nothing smells fried. I tryed swapping the bigger chip and that didnt fix it, could it be the smaller chip? If so what does the smaller chip do?
    Beyond this, I have no clue what else.. I don't know much about ECUs.... Does anyone have any suggestions/solutions? Could it be that it's ruined all together and not fixable?
    92 Honda Accord LX - Sold
    2005 Nissan Altima 2.5S - Sold
    2007 Dodge Charger SXT
    um... it could have gotten fried or overloaded and shorted possibly. but the first few words sums up your problem i believe. he got a non working ecu. as to trying to fix it. just have to test for continuity. thats the best i got.
    Accord SE
    93se
    Members Ride
    Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
    Sold to: sulimed, BurtonRiderT6, tishock
      Cut the j1 jumper in the ECU and try to start it up, It should start up and run, but dont drive the car like that, That reverts it to the stock 1.6L map thats on there.
        And if that works then the ECU is good and can be reflashed or whatever?
        update:
        I put the ecu in aegean to try it and its flooding it like its firing all the injectors when the cars not running( well it wont run the car) but when I plug my good ecu back in the car is flooded so i have to hold the throttle wide open for it to start and you can smell all the gas.
