Hey guys. This is a plain and simple question. I have researched a lot and I'm still drawing blanks. I want to know. I have a f22b, not the 1-2. The Jdm. I would like to put a turbo onto that engine as it is boost friendly with the low compression and what not. I want to know should I use a different head when going turbo? I'm not restricted on money but if I can save some why not. Most posts say the other heads aka h22, h23 , pt3 (I think). Will flow better. Is this true and are there any power gains to be had with them, or should I simply use that money and get more add ons? Thanks fellas. If you have any input please reply. If you have a link that is perfect for these questions please share, because I couldn't really find it. Thanks, bye
I'm a novice with a dream. F22b turbo
Originally posted by Kappicon View PostHey guys. This is a plain and simple question. I have researched a lot and I'm still drawing blanks. I want to know. I have a f22b, not the 1-2. The Jdm. I would like to put a turbo onto that engine as it is boost friendly with the low compression and what not. I want to know should I use a different head when going turbo? I'm not restricted on money but if I can save some why not. Most posts say the other heads aka h22, h23 , pt3 (I think). Will flow better. Is this true and are there any power gains to be had with them, or should I simply use that money and get more add ons? Thanks fellas. If you have any input please reply. If you have a link that is perfect for these questions please share, because I couldn't really find it. Thanks, bye
I would stick with the stock head. What you would make with the head swap you could make much more by turning the boost up a little more. Much easier and much cheaper. There is no real need for a head swap when going FI.
How much power do you want?
The engine is "turbo friendly" but not stock. You need a minimum of forged pistons and a full rebuild for it to not to be a ticking time bomb.
I do not see how it can be done for much less than about $3800 - $4000 unless you get a hook up somehow or find someone with good used parts.
No eBay turbo is worth taking out of the box. There are no short cuts or cheap ways to do it.
Keep researching. Start reading peoples MRT's that are turbocharged and such. And learn about every part in the system before buying anything.
Originally posted by Kappicon View PostThanks for the answer. You helped me. I want about 250-300whp. Low boost with the option to go higher boost. Later. I'll start researching all I'm going to need to boost now. Thanks feller!
You are very welcome. Just start reading. When you are sick of reading read some more. That's what I did. Now I build my engines and my friends. I'm still mediocre at best. Have a goodn'!
I have the f22b dohc turbo Jdm motor and it is no way boost friendly. No stock accord prelude motor is. Also your plan for low boost at 300whp ain't happing. Unless u have a big and I mean big turbo gt45 or bigger. And the motor won't even get the turbo to spin at it's optimal rpm aka start boosting in the 4k rpm range. For 300whp you are lookin at a mid sized turbo around 55trim. A nice gt 30 will do it. With that said you are lookin at about 15psi for 300 whp. If you want boost and reliable boost motor build one or buy the parts and have a shop do it all for u. Other wize your motor will not last at all.
