Failed CA Smog
    Failed CA Smog
    k, Im gonna repost my numbers. Did CA change their emissions standards? I put alot work into my CB7, shes my baby. It ticks me off, when some cheeze dick tells me Im a gross polutor.
    CO2 O2
    Test RPM MEAS MEAS
    15mph 1834 14.8 0.2
    25mph 2528 14.9 0.2
    HC (PPM)
    Test RPM MAX AVG MEAS
    15mph 81 27 36
    25mph 91 21 18
    CO
    15mph 0.74 0.16 0.02 0.32
    25mph 0.62 0.11 0.03 0.04
    NO (PPM)
    15mph 554 270 688
    25mph 511 207 502
    15mph FAIL
    25mph PASS
    Hope Im not missing any digits. Thanx
    Clean your EGR valve and ports.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      I did that like three years ago, but Im willing to clean them agian. How do I get the cup plugs off, the ones the stealership gives you. I took off the original ones off.
        You'll have to drill the cups and use a slide hammer to yank them out. Then replace with new stealership cups.
        90 Accord Ex, F22A4. Slight fire damage.
          Kewel, sounds like found. Especially if you alredy done the job before. Im gonna double check my EGR valve for succion. I think I swap out my cat three years ago, thatsbull shit, im not forking out another $300 to have it replace. Thats crap, thats gonna be the last thing Im gonna try to switch out if it does not want to pass smog.
            how old is your o2 sensor? it could be showing signs of innaccuracy if it's been some time.
            1993 Accord DX | Rosewood Brown Metallic
              Failed a 2nd time. Though my numbers improved my nox# were still high 658 and the max is 554.
              I pulled the egr plugs and valve, sprayed the crap out of it, complete tune up and I still failed.
              I purchased a vacum pum to check egr suction, but Im gonna need a procedure or write up, if anyone has one.
              So here are my new numbers:
              CO2 O2
              Test RPM MEAS MEAS
              15mph 1842 14.9 0.2
              25mph 2562 15.0 0.1
              HC (PPM)
              15mph 81 27 37
              25mph 91 21 21
              CO
              15mph 0.74 0.16 0.29
              25mph 0.62 0.11 0.06
              NO (PPM)
              15mph 554 270 658 (before it was 688)
              25mph 511 207 497
              15mph FAIL
              25mph PASS
                CO2 O2
                Test RPM MEAS MEAS
                15mph 1842 14.9 0.2
                25mph 2562 15.0 0.1
                HC (PPM)
                15mph 81 27 37
                25mph 91 21 21
                CO
                NO (PPM)
                25mph 511 207 497
                15mph FAIL
                25mph PASS
                I think they did change their emission standards in 09'. I'm in the same boat as you. fail the first time, cleaned out the egr, egr ports, failed again. Here is my smog thread http://www.cb7tuner.com/vbb/showthread.php?t=166216 CA smog. They said I need to replace my catalytic converter...again
                http://www.cb7tuner.com/vbb/showthre...13#post2872413
                  Crap! I just had a cat slapt on there two years ago. Its not rattleling, nothing. Im just tying to avoid buying a another cat. Am I gonna have to buy a cat avery other year as I smof it. Thats bull shit. Anyone else got feed back base off my numbers. Thank you.
                    I just check my egr valve for leaks, it check out OK. Any other feed back?
                      Swap out my evap purge solenoid, newone is not ticking. Also, one of the small hoses was leaking so I swap it out. I double check the rest of the hoses for leaks. Im pretty much gonna role into another smog station, not the same dude that failed me twice. Wish me luck & I will post up my results tomorrow.
                      Peace in da middle east my brothers
                        all stations are the same if youre going to a test only.
                        put vacuum to the egr when the engine is running and the car should stall, thats when you know the egr is doing something. plus you really need to clean that carbon out, not just spray some carb clean.
                        I <3 G60.
                          Guess what? Nailed it, my car passed today doing 552 on the (NO), by a hair on my freaking chin chin. Thanks to all who gave a crap
                          I guess I had to go back and do my egr ports twice, get them completely clean, I mean really clean and use a high power vacuum to get everything out. Called my cuz out in Maui, he stated swap out my NGK Iridiums, they burn and run abit on the hot side. So I went out to WalMart & got the cheapest Autolite and roled up to the smog shop & Bingo. I hope what work for me, will work for others. Im back with my Iridiums.
                          Thanks agian
                            I know this is an old post, but it actually the smog history for my car. This are my most recent numbers. Just did a short block swap a year ago with everything else being OEM transfer from one engine to the other.
                            CO2 O2
                            Test RPM MEAS MEAS
                            15mph 1825 13.7 2.0
                            25mph 1889 13.6 2.0
                            HC (PPM)
                            15mph 81 27 49
                            25mph 91 21 46
                            CO
                            15mph 0.74 0.16 0.22
                            25mph 0.62 0.11 0.28
                            NO (PPM)
                            15mph 554 270 994
                            25mph 511 207 892
                            15mph FAIL
                            25mph FAIL
                            Im gonna trouble shoot the basics and hopefully someone will gat back me with a more precise clarification. Have a happy wrenching Saturday folks.
                              Hey folks. Just notice something today. Its getting cold here in the mornings in NoCal. I wanted to put the heater on and the air did not heat up through the vents. Both top and lower rad hoses felt pressure inflated, no leaks. My temp gauge held normal and fans came on when needed.
                              I know of CB7 having (3) temp sensors. Can one of the sensors be related with smoging and throwing my numbers off?
