Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 11-13-2010, 08:32 PM   #21
aventari
aventari is cool... so far.
It is easy to remove the through bolt from the middle and unbolt it from the block?
is it fine to put a jack under the oil pan to hold up the motor when pulling it?
aventari is offline   Reply With Quote
Old 11-13-2010, 08:37 PM   #22
wed3k
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
you dont unbolt anything from the block, the block has a seperate mount which attaches to the motor mount.
a lot of times, i just let the motor hang because you need it to droop down so that you can access the crank bolt.
Before you do anything though, attempt to loosen the crank bolt. i bought a 36" 3/4 drive breaker bar just for removing crank bolts.
http://www.youtube.com/watch?v=RE-pzP8g_x4
I <3 G60.
wed3k is offline   Reply With Quote
Old 11-14-2010, 10:22 PM   #23
aventari
Today I did a lot of work. Replaced the timing belt, removed the balance shaft belt and related parts, and put new p/s and alternator belts, modified the alternator casing for extra cooling, installed new 170F thermostat, put on a good used 1.1 bar spare Miata radiator cap, adjusted all the valves, opened up the air box, gutted some more of the doors, cut out hood bracing, and cut a cooling hole in the hood.
Removing the crank pulley bolt, first I tried my impact gun which never had a prayer.
Next I used a friend's pulley tool and my 1/2" breaker. I had two extensions on the breaker, and this is what happened:
Luckily I kept trying with just one 6" extension and doing a quad press against the bar finally broke the bolt loose. Ridiculous!
Realized I didn't need the upper window frames so cut that off:
Cut a vent in the hood, this should vent post radiator air and hot exhaust manfiold air
I pulled the distributor cap and checked out the contacts. I should probably get a new cap and rotor, except I couldn't remove the rotor.. There's supposed to be a set screw holding the rotor but I couldn't find it and the rotor was on there pretty damn tight. Any ideas?
Old 11-15-2010, 12:02 AM   #24
aventari
Does anyone here track their Accord? Does this fuel tank have issues with fuel starvation on long sweeping corners?
Old 11-15-2010, 12:52 AM   #25
wed3k
theres enough baffling inside the fuel tank to prevent that unless you are running on fumes.
I <3 G60.
Old 11-15-2010, 02:00 AM   #26
aventari
ahh good to know. My old VW Rabbit would starve on corners on anything less than 1/2 a tank and I only found that out on the race track. I didn't want to be in the middle of a the race to find out the Accord does it too
Old 11-16-2010, 04:42 PM   #27
Cobalt
Cobalt is cool... so far.
Send a message via AIM to Cobalt
I will be tracking mine but from my experience anything above 1/4 it doesnt starve.
Call me Travis.
2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
1992 Accord LX ~ "Smoothie"
1991 CRX Si ~ Hellion
1989 GMC S15 ~ Oldie
Cobalt is offline   Reply With Quote
Old 11-16-2010, 05:00 PM   #28
mndude07
mndude07 seems to have made some friends!
Send a message via AIM to mndude07
This makes me so happy. I hope you do well. I see you have some brake ducting going on!
You can remove more stuff. Do you need corner lamps? Side mirrors? Remove the header heat shield since you have that hole in the hood. You don't need the rod that holds the hood up.
Move the battery to the trunk and bolt it down. Weight distribution. Also, you can toss the black box and canister bolted to the firewall. You just need to keep the MAP sensor obviously. You'll just throw a EGR code thats it, no big deal.
Washer fluid reservoir and intake air resonator box can come out from behind the front bumper if you haven't already.
The more weight you can take off the front and put in the rear the better.
There are no black and white suspension answers!!!!!!!!!!!
mndude07 is offline   Reply With Quote
Old 11-16-2010, 08:08 PM   #29
ATS666
ATS666 is cool... so far.
Take off the front bumper and swiss cheese the bumper bracing.
I would love to try something like this!
ATS666 is offline   Reply With Quote
Old 11-16-2010, 10:33 PM   #30
cloudasc
cloudasc is someone to admire cloudasc is someone to admire cloudasc is someone to admire
Ever watch MythBusters? There's an episode where they turn a car into a golf ball with dimples, and it ends up being more aerodynamic. So drive the car through a hail storm before the race, or "simulate" a hail storm to the exterior of the car.
cloudasc is offline   Reply With Quote
Old 11-18-2010, 02:37 AM   #31
Ghetto_CB7
Ghetto_CB7 is cool... so far.
Important
Hey, this hit me tonight as I was driving home.
It was dark, and I realized it will be for part of your race.
Now the stock headlights are not that bad, but make sure they ARE NOT EBAY. If they are get some OEM from a junk yard. The output of the EBAY ones are awefull, you will have to drive slow just so you don't outrun your headlights.
Ghetto_CB7 is offline   Reply With Quote
Old 11-18-2010, 04:23 PM   #32
wed3k
i vote light bar and rally lights.
I <3 G60.
Old 11-18-2010, 05:48 PM   #33
EJX_Michael
EJX_Michael is cool... so far.
Send a message via AIM to EJX_Michael
x2
EJX_Michael is offline   Reply With Quote
Old 11-18-2010, 06:34 PM   #34
Cobalt
That would be beast as sh*t.!
x3
Call me Travis.
Old 11-19-2010, 02:03 AM   #35
aventari
Luckily for us, the don't actually race for 24 hours in the dark, so at the track I will be removing all lights and everything.
Good idea about the bumper, I will pull it off and see about gutting it too. I wanted to move the battery to the rear, but we would have to have a separate vented racing batterybox and a lot of 4 gauge wire and move the cut off switch and there's just not time at this point
The schedule is:
Saturday, 4 December 2010
7:30am: Gates Open
8:30am: Mandatory Drivers' Meeting
9am: Lil'Mons PowerWheels Race*
10am: Race Session I Start
Sundown: Race Session I End
Sunday, 5 December 2010
9am: Race Session II Start
Noon: People's Curse
4:30pm: Race Session II End
5pm: Awards Ceremony
7pm: Gates Close
The people's curse is where all the racers vote on a car/team they don't like, or is driving like jerk-offs or is blatantly cheating, and the "winner" who gets the most votes gets their car crushed by a bulldozer!
http://jalopnik.com/5289202/so-whats...curse-business
Old 11-21-2010, 06:04 PM   #36
aventari
My teammates took it for a track day yesterday and they say after 2 sessions they came in and the car was smoking.
They think the head gasket is blown, but I think it's just an oil leak at the back of the block. It's not smoking out of the tail pipe at all and the plugs look perfect--not steam cleaned and not oily. There is no bubbling in the coolant and no mixing of coolant or oil.
It's possible the head gasket is leaking out of the back I suppose, but is there a sensor or something like that that commonly leaks? Maybe distributor seal?
I'm going to go out there right now and spray the engine down with gunk engine cleaner and see if I can pin point the leak.
Old 11-21-2010, 06:25 PM   #37
islandhopper
islandhopper seems to have made some friends! islandhopper seems to have made some friends!
Cursed!
Im sorry i can't help you with your question, but i wanted to show my support for you guys. I think this is awesome! I hope you guys do well and do all our CB's proud!
Do you worry/care about the curse? How well is it handling? Are you gonna film the event(what you can anyways) take pics or blog it?
As you can tell im quite interested in this and i hope you keep us all posted.
Goodluck fixing the smoking problem and goodluck on race day!!!
islandhopper is offline   Reply With Quote
Old 11-21-2010, 07:11 PM   #38
wed3k
oil pressure sender, oil cooler o ring if equipped.
I <3 G60.
Old 11-21-2010, 07:24 PM   #39
rexload
rexload seems to have made some friends!
Just wanted to say that car looks ridiculous (in a good way). I'd love to drive it on the street.
Hope you get the problem solved and keep racing it!
rexload is offline   Reply With Quote
Old 11-21-2010, 08:48 PM   #40
aventari
Thanks for the support guys!
Good news:
[upper right]
I guess when I did the timing belt and set the valve lash, the gasket got folded under on reinstallation and I didn't notice.
I feel like a retard
