What's up I going to be installing a 1,000 kicker amp in My cb7 and I'm wanting to know if anyone knows where the best place to ground it would be.
Best place to ground amp in trunk
I grounded my amp on one one the 3 rear strut bolts.( if u have a rear
Strut bar you would know what I am talking about) if u dont, then u would have to cut through the stock cardboard looking thing that goes all around your trunk. This is how you get access to your rear strut upper bolts. I try to ground whatever needs to be grounded to these strut rear ( or front) bolts
Cus I heard they get good direct ground contact.
Originally posted by xkjnboix View Postshock tower
Originally posted by lilg4mdalbc View PostYou know like 12 of us already told the op that. Regardless though, if you dont want to cut, you can simply run it under and behind the cardboard covering the strut tower. But if your lazy or impatient like me, then youll do it to the seatbelt bolt. Just remember to sand it down to bear metal, and put some sort of anti rust goo. I just used grease.
