Go Back   CB7Tuner Forums > Parts & Performance > Appearance
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 11-27-2012, 06:34 PM   #101
fleetw00d
Originally Posted by F20A CB7 View Post
I've seen other cbs with wag carpartment but I want to see yours. Mainly the curves where it had 2 b cut... and wat did u use to cut that thich plastic?
I dropped it off at Frank's this evening - they'll do the final buff and repair any damage I did during reassembly tomorrow. I should get it back at the end of the day, then I'll take a picture of the trunk. I read through some other threads on installing the compartment, seems like each one did it a little differently. I used a cutoff wheel to take off about 3/4 inch from the bottom of the front edge (just at the outer ends) of the fixed part of the floor so that it sat a bit lower at the forward end of the trunk and the braces didn't have to be bent to fit over it (they are tight though). I trimmed just the inner front corner of the trunk liner to fit over the forward part of the floor. A sharp knife or razor will cut the liners. I didn't cut any off the sides liners in the back. The pieces of the compartment fit pretty tight against the rear of the trunk, so I did cut some off both sides of the piece that goes across the rear of the trunk (I was in too much of a hurry, may find another one and do a better job of measuring and cutting). I used a couple nut plates to attach the sides of the compartment to the fixed floor piece and drilled and tapped a couple holes to line up with the holes in the bottoms of the side compartments to anchor those to the trunk floor. I also cut a piece of the fixed floor large enough to access the cover over the fuel level sensor without having to take the trunk compartment out; just need a small hinge to attach it.
My wife saw it and said "I want one!". Good thing I picked up another compartment last week.
1/13/2013: Just realized that the cover blocks the trunk light - can't see a thing under it at night. May have to pick up a second light and rig it to the underside of the cover or the back of the compartment (pointing forward).
Old 11-27-2012, 08:18 PM   #102
Accrdwgnguy
aftermarket body parts suck. Yea they are likely using the same mold...from 1991 haha. Hence the bad fit, they usually recycle molds the OEMs toss due to being out of spec.
Love the car however, looks great!
Old 11-27-2012, 09:12 PM   #103
fleetw00d
Even a worn mold shouldn't result in undersize parts though (I am assuming the molds would be metal); it almost has to be that the material they are using shrinks after molding. I took it to the local Keystone store where I purchased the covers - they hemmed and hawed and took a few pictures, but any replacement is likely to be just like the one I have.
Old 11-27-2012, 11:09 PM   #104
Accrdwgnguy
I like to refurbish used OEM parts, you know its going to fit right.
Old 11-28-2012, 05:19 PM   #105
fleetw00d
I'm thinking about it; but I don't seem to have the patience or skill for fine finishing work. I still have the old rear cover; it has some light damage to one corner.
Old 12-03-2012, 10:00 AM   #106
silver91
silver91 is cool... so far.
Has turned out beautiful! Great work!
silver91 is offline   Reply With Quote
Old 12-06-2012, 10:13 PM   #107
F20A CB7
Now that trunk looks nice... you should get a spare 9293 wheel and polish it and put that in the rear as a spare. Just for the sake of blingness of your car. A spare polished 9293 wheel. Come on... idk even our wheels will even fit in there anyways.
Old 12-07-2012, 06:40 PM   #108
fleetw00d
Actually, it is a refinished 90-91 wheel, just face down because that is the only way the factory hold down will work. I suppose I could get some longer threaded rod to lengthen the hold down. A full size wheel will fit, but it is about an inch and a half above the floor. For Ruby, I had cut some pieces of 1 1/2 inch foam insulation to fit around it so the floor was relatively level. The wagon compartment takes away another inch or more because of the thickness of the lid, but you do get the compartments on the sides.
Old 12-07-2012, 08:13 PM   #109
Accrdwgnguy
The wagons come factory equipped with a full size spare, mounted face down. So that is the correct way to mount it, keeps the face from getting scuffed up that way. Plus extra storage space.
Old 12-07-2012, 08:33 PM   #110
fleetw00d
I know that from my wagon; it is a bit of a hassle to have to take it out to check the tire pressure. I have a full size spare for all my Accords. I could put a pad or rag on the face of the wheel to keep from scuffing it.
Old 12-25-2012, 02:54 PM   #111
fleetw00d
Added the pinstripe the other day. Tough to tell in the photo, dual silver stripes. I still have a lot of the roll left; I almost got carried away and put it along the crease in the black rub strip part of the front and rear bumpers, but was afraid it would be too much striping and might not hold up real well to bugs, etc. on the front bumper.
Old 12-25-2012, 02:57 PM   #112
Jarrett
Gorgeous outcome. I'm still trying to find my pinstripe somewhere online. It's just a standard blue, two-line pinstripe but it has a small Honda emblem within it as it goes over the doors. I've never seen it before and it's becoming a pain to find a replacement.
Old 12-25-2012, 03:05 PM   #113
fleetw00d
I've seen that on a few cars. I used 3M tape, the local (Sharonville, Ohio) KOI Paint Store had quite a selection. Have you checked with Honda? Maybe they sell the emblem and you can get the stripe tape elsewhere.
Old 12-25-2012, 03:18 PM   #114
Jarrett
I've checked a few online Honda dealers but not too many cars come with a blue pinstripe anymore. From what Tippey tells me the pinstripe color used to denote the interior color of the car. There are no blue-interior Hondas anymore and searching gets even more sketch when it comes to a style of pinstripe that so few dealers apparently did. I haven't searched in a few months but maybe I need to.
Anyway, this thread is about your car and the amazing amount of work you've put into it. Not my quest for a pinstripe. I wouldn't want to do anymore to take away from this thread.
Old 12-25-2012, 05:38 PM   #115
PakaloloHonda
PakaloloHonda is cool... so far.
Send a message via AIM to PakaloloHonda Send a message via Yahoo to PakaloloHonda
Good Grief ...
I thought I did a good job with my wagon .. but this?
I'd send this thread to Honda of America so fast ...
Congradulations fleetwood .. you have litterally blown my mind with this project!
So far over the top .. this shot below could be from a brochure .. what a sight! Wow!
PakaloloHonda is offline   Reply With Quote
Old 01-11-2013, 08:33 PM   #116
fleetw00d
Not sure why, but I wound up with a rather large gap between the tail light housings and the body. I created a "gasket" out of the rubber lip on the lower rear window trim, attached with 3M double sided tape, so the water from the trough around the trunk runs over the tail lights instead of behind them (and possibly into the trunk as the tail light gasket seal ages). A heat gun really softened the rubber so that it could form to the body when installed.
1/13/2013:
Found my water leak (at least part of it) up front. The windshield seal is leaking along the left side, then drips onto the seat belt track, then the floor. Some must also run down inside the A pillar, it winds up on the floor by the fuse box. Looks like I'll get a new windshield after all.
1/28/2013:
Well, one thing leads to another. Windshield guy showed up at the house and started cutting, but his knife went further than is was supposed to. Stopped right there, drove it to the body shop where it was painted before completely removing the windshield. It wasn't pretty. Previous windshield replacement apparently wasn't treated properly.
For an additional amount about equal to that of the windshield, the body shop cleaned up the rust, treated it, formed some patch panels and used adhesive to install them. Windshield guy was pleased with their repair - windshield went in no problem. On the bright side, it was out in the rain last night and today - no evidence of leakage.
My complaint to Keystone about the rear bumper cover paid off (sort of). They offered to exchange the aftermarket cover for a "reconditioned" OEM bumper cover. Took a look at it today, I couldn't tell where (if) it had been repaired other than the paint being removed. I will have to foot the bill for painting it. Photos of fit problems with the aftermarket cover:
V Top edge warps inward around support .................../\ Front edge doesn't match wheel well
01/30/2013:
Spoke too soon. No leakage at the A pillar that I can see, but the driver footwell was soaked after another day of rain. Still looks like it is coming down in the left front corner (water on the vertical sheet metal behind the panel around the fuse box). Drying it out, then restart troubleshooting.
04/19/2013
I finally figured out the leak a while ago, forgot to post. I figured out that the water was coming through a seam at the base of the left lower corner of the windshield. An application of some of my remaining auto body panel adhesive has solved the leak.
http://www.cb7tuner.com/vbb/showthread.php?t=197324
Old 04-18-2013, 11:53 PM   #117
dhill_cb7
dhill_cb7 seems to have made some friends! dhill_cb7 seems to have made some friends!
Wow ruby looks amazing, sorry about the rust issues and the leaking from the windshield.
i know i have not been on in awhile and i am sorry, been real busy finishing up school.
dhill_cb7 is offline   Reply With Quote
Old 04-22-2013, 10:22 PM   #118
fleetw00d
Better late than never. Photo of "remanufactured" OEM rear bumper cover after being painted to match - fits much better than the aftermarket cover.
Old 06-06-2013, 09:08 PM   #119
fleetw00d
No Good Repair Goes Unpunished
I was worried about the first ding. Got a little more than that this morning; got rear-ended. broke the bumper beam (obviously messed up the cover), pushed in the back of the trunk compartment maybe 1/2 inch, trunk lid is little high at the right rear corner, but I think that is because the latch area is pushed in. Looks like I'll get my opportunity to change to the 92-93 rear bumper (already have a powder coated rear bracket and several bumper beams). Pictures later.
Old 06-11-2013, 03:09 PM   #120
stevediraddo
stevediraddo is cool... so far.
Send a message via MSN to stevediraddo
LAME! I'd be in jail for attempted murder by now
after all that work too.. sorry about your rear end bro
My Cars: 2006 Ford Freestyle - 1990 Accord EX - 2001 Accord EXV6 Coupe - 1967 Impala "Metallicar" (for the wife)
stevediraddo is offline   Reply With Quote
panel , quarter , repair , rust
