Question about F23xx vtec head on F22a4 block
    Originally posted by 8ball View Post
    Some one should make a big giant sticky of WHY not to ask about making a F/H frankenstein
    Good sir, you may have inspired me!
      I think PR CB7 should do it.
        Sorry Deev, I already had let to go start it.
        Here it is.
        http://www.cb7tuner.com/vbb/showthread.php?t=187140
        It's in the performance section. It will be a work in progress.
          My post was a joke... Oscar and I have been arguing about hybrid swaps for years now...
            The F22B1 has the same bore size as the A1, so that is better... but honestly, the F22B1 head is a downgrade from the F22A1. If you want VTEC, get an H22A. Don't waste your time with the SOHC VTEC.
            Turns out i was given the wrong name of the head, its actually an F22xx vtec head. Either way i agree with you im just gonna wait for my taxes (lord knows when that will come) and get the H22a with lsd tranny? Thanks Deev
              Originally posted by SOHC-FTW View Post
              IIRC all USDM F22A/B/23's use the same cumbustion chamber size aswell as the h23's here in the states.
              Also contrary to popular belief the F23 heads flow quite nicely it and the F22b flow even better on the exhaust side of things compared to the F22a. The F23 has just as much potential in my eyes as the F22a once modified the F22b is the bastard child.
              i guess ill just rebuild the F22 and keep it on the side or sell it
                sig material YESSSSSSS
                Just do what PR CB7 said.
                  on another note
                  in paper or theory mght not work but in real life it does
                  think about this....
                  when you bore a motor .50 over what headgasket do you use?
                    There are a few, (key word FEW), members on here who have seen some decent results through a frank build; though often these are turbo motors; actually a few of the best turbo build made public on this site are franked.
                    I have yet to read a sohc Vtec major build, (without turbo), that even comes close to the bang for the buck on an F22AX motor.
                    I once had a local buddy, (who has connections at all the local junkyards), offer me a freshly rebuilt h23 head, the f23 headgasket, timing belt, and an f22b dohc ecu, all for 100 dollars. This is close to 90% of the list required to do the H23 frank motor, the "Best" way, as built with a nice DIY by "WiKKeDV16". I looked for the DIY but I could not find it. But I went on the site and spent a few hours and found out that all this would accomplish was less than F22b dohc power. It is less because the f22b has higher compression pistons, 9.3 vs 8.8.
                    Since then I no longer understand the reason to frank these motors when the same effort and time that one could put into such a project, could easily be outdone by simple 1.5 level cam upgrade with an h23 intake mainfold, with this an ecu is not neccesary, but you should be running an A6 ecu at least.
                    If you want to go a bit deeper, you would have a very nice motor by swapping in raised compression pistons; nothing ridiculous, 9.5ish is decent, and still a huge upgrade over the 8.8 stock. You couple that with a level two cam, and an h-series tranny, and you will have a very nice combo, (Stick with the F-series tranny if you like acceleratig on the roll, or Highway MPG). but you would need a chipped ecu; Easier to get accomplished on here than some will have you believe, IF YOU MAKE THE RIGHT FRIENDS ON THIS SITE.
                    H22 is nice, also easier than rebuilding a motor, but when you pop the hood and people see the H, they go, oh its an H, no wonder. Nothing blows people's minds but to have been beaten by an f22ax that looks bone stock. All that being said, H22's look absolutley beautiful under the hood of a CB7, and sound nice too. ALSO, considering its a "Bolt On" 16-15 second 1/4 mile upgrade, its hard to match in the bang for the buck category, and also its super reliable. H22's can be found for cheaper, but you start to lose the reliablilty factor the cheaper you look, but sometimes you get lucky.
                    I drive a 94 accord Ex with an f22b1 vtec. My old 93 accord lx, (f22a1), with a p12 ecu, (honestly saw no difference when I added that ecu), f22b (dohc) Intake manifold, f22a4 exhaust manifold and downpipe, and stock exhaust was just as quick. And the stock listed HP numbers were 125 vs 145
                    There are MANY options that are all far better than an incorrect head swap for the f-series motors. If you are going to "frank" anything you should consider an h-series transmission. Its quicker off the line, however your highway MPG will suffer.
                    All of this info can be found on the site, its just waiting for people to search for it.
                    _
