So I just got it because I thought it was sexy. I guess most people put it on the alternator bracket. I wanted to replace the original dogbone with the NRG but the eye hooks are too small to fit the front mount bolt unless I get rid of the bearing inside the eye hook. Kinda dont want to do that.
So I was thinking about using the nrg in parallel to the dogbone as well as filling the bushings with polyurethane. Ideas opinions?
Also those bolts are on there tight even with pb blaster. I know the lower passenger side is welded on but I think thats the only one right?
Heres what the insides of the NRG torque damper look like.
Red bushings are poly black are rubber
