ok, I understand a little more now.
Extended tophats
they are still very useful on full coils. i have astros omnis with front extended tophats. let you go even lower than normal without sacrificing much, if any shock travel.
the omnis will go lower than the chassis will allow because of the UCA's and still have enough shock travel to legitimately have a decent ride without blowing the shocks.
Most decent coilovers provide ride height adjustment by extending or contracting the shock body. If you do this, you don't compromise piston stroke / travel. Ground Control is an excellent example of a decent/high quality coilover sleeve. With a sleeve or lowering spring you have ride height adjustability @ the expense of shock travel. That is why an extended hat is needed.
how can i make my own? or that pic posted above what do i need to make one like that?MY FOR SALE THREAD
My Recent CB
My Old CBs
1991 Honda Accord EX - MY NEW ONE
1991 Honda Accord LX - Impounded and GONE
1993 Honda Accord EX H22 - SOLD
BTW IM NOT TURBO.. I WAS GOING TO GO TURBO WITH MY FIRST CB.. BUT IT GOT IMPOUNDED
Originally posted by Flatline View Postthey are still very useful on full coils. i have astros omnis with front extended tophats. let you go even lower than normal without sacrificing much, if any shock travel.
Truth. The extended tops that I had made allowed the whole shock to travel past the OEM upper mount location... So even on the floor, the car still rode hald assed good .... then the floorpans stayed off the pavment.
If I had used an OEM top and bumpstop WITH NO SPRING AT ALL ... the car acaually would have sat higher then it did with with the OMNI's and extended tops.
Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
Originally posted by slammed4thgendustin, you are a dick!
officially the lowest ive seen now
Originally posted by CB7xTURBO View Posthow can i make my own? or that pic posted above what do i need to make one like that?
Buy proper lowering spring/struts.
Or, IF you are going to do it like that pic, at LEAST make sure you use industrial grade bolts, and use tube spacers to take the load rather than an extended bolt.
My 5.7 LS1 Holden Ute
yeah trueMY FOR SALE THREAD
My Recent CB
My Old CBs
