J32 Swap???
    J32 Swap???
    Is it possible to do a v6 J32 swap into a cb? I know anything is possible with enough time and money but has anybody done it. Just curious about all this.
    Soon to have the first *Bottle Fed Accord* in MI!
    Vouch For: fatboy1185
    It has the room for it. The only problem would be getting the axles perfect really. The rear mount would be kind of difficult in my opinion.
    Testing your knowledge and your wits.
    Need 10th anniversary wheel center caps. PM if you have them
      anybody ever do it?
        It has never been done as far as anyone on this forum knows.
        But it has been measured, planned out, and there are a few members saying that they're working on it.
        EVERYTHING would have to be custom, but it is certainly doable. If you can fab the mounts, axles, wire harnesses, and anything else that has to be changed, then you can do it... or if you can afford to have that done for you. There shouldn't be any significant changes to the car itself to pull it off, though.
          im pretty sure you can i saw it in a civic so i could imagin accord
            There are threads in the technical forum about it. Some of the more knowledgeable members here have gone into considerable detail discussing it.
              ok thanks deev
                K-1 Attack / accord cradle TL J32 transplant
                This may have been discussed already [sorry...newbie here], but has anyone done an engine transplant of a J32A1 TL Acura 3.2 engine & tranny into a 1990 Accord??? more so, ONTO a 1990 Accord cradle!!!! I am building up an Attack K-1 [see link >>> [ attackforums.com ] that is already designed for a donor cradle from this early 90's Accord .... I have a 2003 TL engine/tranny/wiring/ECU/etc. available that I want to use vs. the H22 that has been normally used in this car.... I'm using a 1998 Legend front suspension assembly [w/new coilover setup the Attack is designed for] and want the drive shaft to align correctly, etc. and want to see if anyone has used the TL's mounts on the Accord cradle.......... the OBD-II wiring/mods will not be an issue, as I did a F355 Ferrari kit car conversion using a 1998 Grand Prix 3.8 V6 a few years back [now For Sale here in Denver on craigslist to make room for the Attack project .. ] .... any assistance is appreciated ........... "
                  if you want answers to your questions go post a thread in the technical section. itll bring in alot more answers than youll get here. this thread is really old.
                    just an FYI ... you should be able to use a lot of the stock parts from the CL just minor modifications would have to be done...
                    in the process in getting most everything to attempt this... won't have the complete motor but just a mock up... to make sure the axles and motor mounts will be in the right place and a good fitment !! doing this J/Y style !!
                    Originally posted by Devergote
                    A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                      If a J32 can be fitted in a EJ/EG/EK civic,why not in a CB accord???An H22 fit tight in a civic but got plently of space in a CB... I think everything is possible whit some money,times and patience!
                      MY RIDE PAGE 2010:http://www.cb7tuner.com/vbb/showthread.php?t=163097
                      2009:http://www.cb7tuner.com/vbb/showthread.php?t=146532
                        I believe he was quoting a thread that was already made about this subject.
                          all you need is money and the mind set to do it. Patience and fabrication skills will also help.
                            DONE ... my J32a1 in an Attack K1
                            well it is done ....... not that much cash & some fabrication required [mount & frame mods in my case...]; hardest part was determining axle centerline locations.
                            check out my build pix here>>>>
                            http://s47.photobucket.com/albums/f1...pyder%20Build/
                            NSX front calipers on the rear 5-bolt TL hubs, etc.
                              if they can do it in a integra im sure it can be done on a cb.
