I need help 5 lug
    I need help 5 lug
    I am trying to figure out what knuckles these are so I can buy new brakes and if it's the correct swap. I salvaged this front 5lug knuckles from a 91 cb7 coupe
    Right side is stamped 70 R LX02?
    Any clue what car they came from originally?
    a person who looks at somthing and see it as waste is no person at all but he who see what it could be will suceed
    I have two different 5 lug knuckles laying around. Let me go see if any of them have that stamped on it.
      Do they have press-fit bearings or bolt-in bearings. If they are bolt-in bearings, then they are almost certainly Odyssey/Oasis knuckles and you can buy your brake components to fit based on that application. The only other way they could be bolt-in bearings and not be Odyssey/Oasis knuckles is if they were CE Accord knuckles with Odyssey/Oasis hubs installed. Even still, the same would apply as it would to the full Odyssey/Oasis knuckles in terms of which brakes you can buy.
      If they are press-fit bearings, then it's likely done with '97-'01 Prelude knuckles. The stampings don't match the V6 Accord/TL/CL stuff.
        hmmm i see
        i have to check but it diffidently has 4 bolts in the back.
          hey were do u host ur images for html stupid photo bucket is making me pay 40 bucks a month now that's why i can see non of my images. i am not paying that.
            thanks alot what year odessy ima pull the rotor off and try to match them at the part store.
              '95-'98 Odyssey. It doesn't matter which trim. The '96-'99 Isuzu Oasis is identical.
              They are an 11.1", 25mm-thick rotor. The caliper brackets should also have "25T" stamped on them.
                Thanks a lot I really appreciate it
                  I'm still using PB. I'm riding out the time I paid for which is good until 2018.
                  And that number does not match anything I have for a 5-lug swap...
                    hey i need some more help does any one know what other vehicle uses that bolt on bearing besides the Isuzu i need to get a replacement bolt one of them snap and i cant find a diagram for the odyssey from Honda to buy a new one.
                      Ask and you shall receive!
                      #22; 90164-SM4-013.
                        wtf
                        #22; 90164-SM4-013.
                        what the hell are you a cb7 god or what ... were did you find that.
                        i ordered m10x1.24 40mm from dorman its a 10 pack. but its completely threaded all the way threw...
                        do you have a part number for the oem bolts. number 22 on the diagram..
                          That diagram is available in most places, just look under > Chassis > Brake > Front.
                          This is also why I had all my microfiche scanned, so I can have all of these on hand.
                          90164-SM4-013 is the part number, used on a wide range of Honda and Acura applications.
