Oyajicool : 1993 Accord LX (2)
    Brake Master Cylinder RR @170329
    Needed to pump thoroughly due to pesky little air.
    Making sure to have this end of hose submerged,,,
    Vacuum pump with a tank was used to suck up old fluid. Then used a paper towel to take out the remaining fluid.
    Since priming on a bench vise was thorough, almost no air had entered in the system. Flushed old fluid out from each corner.
    A&P-IA
      Noise from front as making turns @170335
      Noticed the car was making funny noise with first input on steering wheel as making turns. Checked the reservoir for steering. It seemed low, so added some fluid.
      The noise went away.
      A&P-IA
        Rusted Holes, Temp Fix @170335
        PO had applied silicone to holes. Rust is occurring underneath.
        I used a wire wheel to remove silicone and rust. Then applied Ospho to stop rusting.
        Then, taped up holes as temporary means.
        I think I will use fiberglass to fill the holes when I have more time.
        A&P-IA
          Brake lamps @170335
          Brake lamps were not working.
          Checked the switch and found the bumper is missing.
          This should make the lamps lit all the time.
          Checked the fuse.
          Its terminals are corroded.
          Got a replacement.
          Pulled other fuses and applied lube.
          Got some hardware to use as the bumper.
          Installed.
          Checked the switch.
          Installed.
          Now, the lamps work on left side only. Need to check for ground on right side and third lamp next when I have time.
          The horn works now. As well as the solenoid for shift lock.
          A&P-IA
            R/H & Top Brake Lamps @170408
            Checked light bulb. Corrosion found and cleaned.
            Still, the lights does not work.
            Ground is good.
            GRN-WHT wire is a suspect, now.
            This connector is sitting on the light assembly. There's voltage coming in this far. Next suspect is the connection into the light sensor.
            Pulled the connector and found bad corrosion.
            After cleaning the terminals, applied some lube to prevent corrosion.
            Then, hooked up the connectors.
            A&P-IA
              Starter motor @170502
              Disconnect ground terminal
              Remove air box
              Remove power cable and control wire from the starter
              Remove mounting bolts (2ea)
              Extract the starter motor
              Replacement starter motor
              Make sure to install a new terminal nipple since the old one was torn as it was removed
              A&P-IA
                Wash down the engine @170704
                Before:
                Stuff I used:
                Water:
                After:
                Somewhat better now.
                I need some brushing action next time.
                A&P-IA
                  how did everything turn out with the repairs to the BISI header??
                    Bisi Header
                    If you read one of my threads about it, you know even Bisi could not fix the thing.
                    It is the best, most expensive dust collector I have in the attic.
                    I may do something about it when I have enough time, skill and money.
                    A&P-IA
                      Wiper blades @170787
                      You cannot get just the rubbers any more, huh?
                      A&P-IA
                        R/H Blinkers @170804
                        R/H blinkers started acting funny. Back one does not blink.
                        Troubleshooting revealed a bad plug.
                        Replaced it with 9-pin-connecotor from the Shack.
                        Making sure the correctness of wire arrangements.
                        Triple checked and connected. The blinker works now, along with other lights in the assembly.
                        Changed this leaky gasket
                        with this.
                        A&P-IA
                          Front calipers and hoses @170857
                          Got these online.
                          Painted yellow.
                          Got these, too.
                          Installed.
                          Let the air out.
                          A&P-IA
                            I wasnt aware that Russel made brake hoses for Accords. I looked into it and was only able to find versions for front disk and rear drum. Meaning that i wouldnt be able to use them with my setup. They are a really nice piece though. great find.
                            Purchased From: busak87, GunRunner, Bruce Banner, Itstatcb7kid707, tJoods, DannyD
                            The Caravan 2015
                            MRT:http://www.cb7tuner.com/vbb/showthread.php?t=180919
                              Thank you.
                              Googled "Stainless steed braided brake hoses, 93 Honda Accord" and it led me to either Russell or Goodridge. Russell was DOT approved, and was for less.
                              A&P-IA
                                Radiator cap @170910
                                After engine shut down, there's funny noise coming from front. It was coolant reservoir, bubbling. Water temp gauge was normal indication.
                                Assuming it is due to bad radiator cap, I got a new one.
                                Checking the old one. It sure looks old and was the cause of the bubbling.
                                It couldn't keep the pressure and the coolant was boiling.
                                Had couples of drives since the cap replacement. No more funny noise.
                                A&P-IA
