car smells like its overheating when its not one person told me it could be do to the fact my exhuast is broken
car smells like its overheating but its not an ideas?
What does your temperature gauge look like? Any leaks from hoses? Leaks from water pump?-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-2012 GMC Canyon V8 4x4
yeah, I've just dealt with the effects of an overheat, check all of the hoses quickly, and the antifreeze level. Trust me, you don't want a warped head. Its best to replace the bad parts or hoses rather then taking the engine half apart because you overheated the engine. Some of those hoses are hard to see or inspect. You may have to take the intake plenum off to see the ones under the intake.
Originally posted by Skidd View Postyeah, I've just dealt with the effects of an overheat, check all of the hoses quickly, and the antifreeze level. Trust me, you don't want a warped head. Its best to replace the bad parts or hoses rather then taking the engine half apart because you overheated the engine. Some of those hoses are hard to see or inspect. You may have to take the intake plenum off to see the ones under the intake.
