I just had my tires filled with nitrogen and the guy aired it up to 35psi. Now the sticker on the door says 29psi and to me that seems a little low. In all this sites infinite wisdom has anyone found the true optimal tire pressure in regards to better gas mileage and tire life. I have stock wheels
Optimal Tire Pressure
From a guy that works in the tire/service industry I would always put the pressure to what it states on the door. That pressure is specified to account for suspension and ride quality. It does not matter if you have OE tires or not as long as they are the correct size with OE rims then the pressure should be set to what Honda recommends.... My 2 cents
Originally posted by cmhondaboy View PostFrom a guy that works in the tire/service industry I would always put the pressure to what it states on the door. That pressure is specified to account for suspension and ride quality. It does not matter if you have OE tires or not as long as they are the correct size with OE rims then the pressure should be set to what Honda recommends.... My 2 cents
The tire pressure on the label/door takes only into account factory wheel that came with the car along with the specified tire that came with the vehicle. If you change those dynamics, the whole game changes. Read the manual as it should explain more in detail. You have to take into account changes in altitude, climate conditions, and other factors.
My door jamb says 32 psi, but I have an EX coupe. However, I'm also 5-Lug converted with TL wheels and slightly stretched tires. When they were mounted and balanced, the shop recommended 40 psi, so that's what they were aired to.
Since your going Nitrogen filled, depending on your location, I would say some where between 32-35 psi. Look at your tires for recommended tire pressure.The Lord watches over me!
- D. Chappelle
I have to disagree but to each their own.. My shop goes off MACS guidelines and I always compare door to what the updated specs are and they are 99% of the time the same.. As far as fuel mileage goes I have checked it at several different pressures on my CB and my SUV and thus far have gotten the best mileage from factory pressures.. Even if it is 20 years old they did it that way for a reason... If they wanted to change it for safety they would release a TSB stating other wise.. But everyone will have a different opinion on how much to use.. Even guys in my shop disagree on this very issue all the time lol
Too much air will wear the center of the tire more, too less and it will wear the edges. Doesn't matter factory tires or not, Honda doesn't make the tires and factory specs are best. If you have 100 lbs of stereo in your trunk you could add alittle more air.
Having changed hundreds of tires at a tire shop I would usually just set them to 32psi.
Originally posted by illinois_erik View Postgo with what it says on the sidewall. Mine are 44psi max so I put in 43 to account for heat expansion. the sticker on the door jamb is for the OEM tires
max tire pressure is the maximum pressure the tire can handle
The sticker is for tires equivalent to OEM tires. Putting in more pressure will cause it to balloon and wear the center. The door jam spec accounts for the weight of the vehicle. The tire pressure you want to use is the tire pressure on that sticker. The max tire pressure doesn't account for the weight of the vehicle its going onto, hell the car could be heavy as shit which would mean you would need more air in it to retain its proper contact patch with the road.
I use 35psi all the way up until winter, I deflat them some so my tires can dig in the snow more. Always worked for me.**Blk Housed Slut Crew Member #1**
The sticker is for tires equivalent to OEM tires. Putting in more pressure will cause it to balloon and wear the center. The door jam spec accounts for the weight of the vehicle. The tire pressure you want to use is the tire pressure on that sticker. The max tire pressure doesn't account for the weight of the vehicle its going onto, hell the car could be heavy as shit which would mean you would need more air in it to retain its proper contact patch with the road.Last edited by illinois_erik; 06-25-2012, 12:17 AM.
Originally posted by illinois_erik View Postit took 120psi to seat the bead even lubed up on my alloys, whys it a terrible idea? if its 42-43 psi and the max is 44 i dont see a problem, just like most tires are max 35psi you put in about 32-33..
Most tires max PSI is not 35 either.
