#2081 |
Always nice seeing Sally making progress.
#2082 |
Excellent progress! Transmission and paint are still two areas I haven't gotten my hands into yet. I can appreciate your persistence on the spoiler. It's looking really good!
#2083 |
Islandhopper/Apalileo, with both of your sigs near each other your cars look alike. But ya, on the weekend I spent another 45min buffing the spoiler. But I just cannot get it shiny. I know there's enough clear on it so I'm thinking it's because I don't have a high speed buffer, just a low speed crappy one.
#2084 | |
I'm no expert in polishing haha, but when in doubt there's a million Youtube videos on how to polish paint. This video really helped me: https://www.youtube.com/watch?v=IQF9ZrzxkCE
I'm faster then a prius
#2085 | |
#2086 | |
![]() That gray color you were talking about was the clear coat being scuffed up, he didn't go through the paint. (That's how it's supposed to look) The black color is under the clear coat, he was just sanding the top (or clear coat) to smooth it out (get rid of orange peel and imperfections), then polishing the 1500-2000 grit sandpaper scratches out of the clear coat. The paint before sanding and polishing was shiny, but it had orange peel keeping it from looking like a mirror finish.
#2087 | |
Well... finally gave in and bought a Syncrotech bearing and seal kit. Wasn't cheap with exchange rate + shipping + customs fees. ![]() Last edited by Raf99; 07-01-2017 at 08:43 PM. |
#2088 |
Looks like quality parts so "cheap" is out of the question. I would likely not want to associate cheap parts with anything as mechanically precise as a transmission anyway. Looking forward to seeing it all come together!
#2089 |
ya, now the only decision i have is to cleanup and paint the transmission? If I do this I'll want to do the block too
#2090 | |
I used it to clean mine and it worked really well, I put it in a spray bottle and went to town with a toothbrush. ![]()
#2091 | |
#2092 |
Raw aluminum gets my vote, that's what I on my 91 SE which doesn't see any rain or road salt so I went nuts cleaning up all the aluminum parts with wire wheels, grinding stones and sand paper. I think your engine bay looks phenomenal the way you've done it. But do as you will
#2093 | |
![]() I got a jug of it from a local Walmart. Here's what the jug I got looked like: ![]() It was like $10, near the painting isle. It's really cool stuff cause it only faintly smells like mineral spirits.
#2094 | |
Ya, i got this from canadian tire. ![]() Took the transmission fully apart today and gave it a cleaning. Ran into issues trying to remove the counter shaft bearing. This is what I used along with a torch the outer area. ![]() So we have to take the gear teeth health into consideration. Something I never thought of before. We have the following; 1. My car, installed with a OEM H22A transmission 2. An OEM T2T4 transmission from japan 3. A spare set of MS and CS from a 93 accord (gears are grinded down bad). I took the 5th gear set from these to shave down 4. Synrcotech 5th gear set (same specs as the set above) Now, my issue is while I have a new set of synchros installed all the gears are used. Determining the best gear teeth to use is not something I know how to do, and I'll have to rely on pics and google. I don't believe any of these gears are any good. .... I also realized that the T2T4 is missing a washer. ![]() #3 is missing from the T2T4 tranny. ![]() ![]() ![]() ![]()
#2095 |
Soooo, the #3 in the above pic is a shim. And there are different sizes. But for OEM spec are two required at either end? Did my replacement trans from JDM not need it or is it missing it or did someone take it. Hmmmm
Anyone know ? (#3 & #4 of this pic) |
#2096 |
New MS/CS bearings installed. And MS/CS are assembled. Just need to find torque specs...
#2097 |
Looks like it's coming together nicely!
#2098 |
Slow and steady eh. But lack of documentation is my issue now. Store sold manuals don't get into transmission shimming, but from what i could find the diff max clearance is .10mm (.004in). Well I can fit a .50 + gauge in there. So I'm pretty sure I need that shim.
I'm going to try and find manuals online that will tell me the answer to this and also order that shim. |
#2099 |
wtf...... 12min into my jog today I heard the loudest pop from my lower calf muscle and the next step was not a pleasant one. Took me 20min to limp home, that was painful. .... I heard/felt this pop over my music/headphones, it was brutal..
Dare say we won't be jogging for 4-6 weeks... ![]() |
#2100 | |
![]() Hope you feel better dude! Edit: I looked that up, torn calf muscle? Oh God that sounds terrible.
Thread Tools | |
