Hello CB7 Family,
i recently tackled the fix for my surging RPM. I have read a lot how to fix; reference this thread: http://www.cb7tuner.com/vbb/showthread.php?t=206012. Thanks for everyone's past comments and knowledge from your CB7 experience.
I am almost done and i was about to put everything back together BUT I decided to replace the hoses to IACV and FITV to ensure no leaks from those little hoses. To gain more access to replace the hoses, i removed the EGR.
HERE IS MY CONCERN: The EGR port was filthy, which is common. I sprayed some carburetor cleaner down the two ports where the EGR sat. The next morning there was a lot of dried up black debri (carbon). Needless to say, i dug most of the carbon out BUT--
1. Will the other loose and/or hard to reach carbon in the ports near the EGR port cause damage to my engine if i start the engine to finish my surge repair?
2. Should i remove the TB and IT Manifold and clean them?
I am just a medium skilled car mechanic and i just dont want to remove anything and re-install it to cause more problems. lol
