#1 |
CB7tuner Member
Accusump Setup...A lot to consider
Well, after the shiny microsopic shavings in my first oil change after the H23A swap, even with the Moroso pan (raced at Laguna Seca), I am set on the accusump for the extra level of protection.
Canton Racing provides this selection guide to help you make your choices. Here is what I am sure I am purchasing based on the guide: - 2 Qt. Accusump - 10AN Hose and Fittings - 2 Utilitarian Mounting Clamps The two things I am not sure about are the plumbing and the valve setup. 1. For plumbing, I want to ask you guys if there is a 1/2" NPT or at least a 3/8' NPT fitting unused somewhere on the JDM H block. Directly plumbing this into the block seems like the easiest method overall, especially when I consider the new oil capacity of the motor. Since the H blocks already have an adapter for their mini oil cooler, I am not so sure another adapter on top of that would be wise. The other options they mention are T tapping the accusump into remote oil filter and oil cooler pluming, which would obviously cost the most, be the most work, and make determining the new oil capacity at oil changes the most difficult. To keep a reserve of oil cool, I could just install the accusump in the cockpit rather than the engine bay, and it would then release a reserve of cooler oil into the block in hard cornering situations. 2. I am even more unsure about the valve choice, and here is why. I need more info on this, but I found Ghost once writing on here what our warm idle and 3k rpm oil pressures are: - Warm idle: 10psi - 3k rpm: 50psi I'm guessing the oil pressure is even higher near the redline. This large fluctuation makes valve choice really difficult. If I use a manual ball valve, then I would just open it up before startup to prime the block, then close it after I start the car, which would allow oil to recharge through the one-way valve back into the accusump. I would then open the valve once on the track to allow discharges and then have to close it again once leaving the track to avoid excess windage while not racing. If I use their fancy electronic valve with the pressure switch, I am not even sure which one to buy, since they say one thing on the selection guide (go with 25 psi but turn off after start when at idle and turn on when entering the track) but another entirely on their blog post on the website (use the one that matches operating psi and shut valve off at idle). The only positive I see to the fancy valve is the option to have an indicator light wired to the dash so I can see when the accusump is discharging. I guess there is also the need to properly set the precharge of air in the accusump. Should that be set at whatever the psi level is somewhere in the middle of the revs, such as at 5k rpms? Some of you are probably wondering why I see this as a necessity. Well, last time I went to the track (only time on new H23A motor), the car had trouble engaging vtec during cornering when it was actually in the proper rev range for vtec. I know I am not running a pressure switch, but doesn't the solenoid still check for proper oil pressure before engaging vtec?
__________________
*** Think of others before thinking of yourself. ***
********** Spread love, not hate. *********** ****Lift others up with kind and helpful words**** F20A_CB7, I miss you, but I will see you one day. "Nothing a little prayer can't fix." MRT Selling on Ebay! ![]() 15.10 @ 90.42mph The quest for 9s ceased, now the goal is a circuit track monster! Current fastest Laguna Seca Lap: 1:55.317 |
#2 |
CB7tuner Member
Yes. The Solenoid looks for oil pressure & correct temperature.
So if there was not enough oil or not hot enough then it will not engage.
__________________
Keep Pushing.. |
#3 |
Gold Member
I'm not pro on the topic but it's the 3/8" on the back of the block you want. My turbo oil feed is there now. (for example) looking at this page.
"The preferred port size is 1/2" N.P.T., however, 3/8" N.P.T. is acceptable." And if you wanted a 1/2" you'll have to drill and tap. For a race car, manual makes sense. The more expensive is for the lazy i guess. Or auto features etc. Go big or go home? ![]() |
#4 |
Contributing Member
I can tell you at least with my car oil pressure at redline is about 80-90psi. During warmup it sits around 60-80 until it’s up to temps. Then at idle it sits about 10-13 and yes above 3k it’s over 50 psi.
__________________
~Nick~ FSAE (F Series Accord Enthusiasts) ..."A dying breed thats taking it to the next level" Lucky #13 MR Thread:http://www.cb7tuner.com/vbb/showthre...ight=Grumpys93 ![]() |
#5 | |
CB7tuner Member
Thanks for all the help, guys. I must've not had adequate oil pressure in some of those high velocity corners...
Quote:
![]() Here's another picture. The plugged hole I am talking about sits right below the leftmost intermediate shaft bracket bolt hole: ![]()
__________________
#6 |
Gold Member
Right below the oil cooler/filter. (The one you are looking at I believe is a coolant freeze plug (but i'm not 100% sure))
#7 |
CB7tuner Member
Ok, I see. It looks like you have two extra pieces sandwiched between the block and the oil pressure sensor. The brass colored one is a T with a 3/8" NPT thread? Did the two pieces come as a set?
__________________
#8 |
Gold Member
It's a 3/8" and it's also where the OEM oil pressure sensor /switch was. I have a T-fitting for the turbo line and the bras thing is the oil pressure gauge in the A-pillar. (want the pressure read where the turbo oil feed is).
#9 |
CB7tuner Member
I found one of those T fittings from KS Tuned and it looks really nice, but the fittings are 1/8 NPT.
![]() That seems to be the standard for turbo oil feeds and oil pressure gauges on Hondas, and that is too small for the Accusump. Man, I really want to avoid the sandwhich plate if I can...although that is one of Accusump's suggested options. I have just heard that they leak.
__________________
#10 |
Contributing Member
Are you sure about this one? Pretty sure the solenoid only activates VTEC and has no "sensing" capability.
#11 |
Gold Member
To add to this, while the hold coming out of the block is 3/8" (I think) we know the turbo line feeds are 1/8.
#12 | |
I shoot people
go with the automatic if you can. the manual is a pain in the ass if you forget to do the procedure perfectly every time
__________________
![]() Click for my Member's Ride Thread Quote:
#13 | ||
CB7tuner Member
Quote:
"Designed with 1/8BSPT male thread to match Honda Block. The adapter offers a couple nice features to help installation and prevent problems." After I did all kinds of research, I figured out what that means, and it makes since to be BSPT vs. NPT because this block was machined in Japan. I guess I am out of luck for that port, since I must have at least a 3/8" line for the Accusump. There is such an array of sandwich plates out there, I can't even begin to tell you. Canton wants $110 for their 20mm x 1.5 plate! I can find it for just under $100 with shipping on ebay, and it has a single 1/2 NPT accessory fitting. Still, that is pricey! The only other thing I have to check is the O-ring diameter compatability. Canton's plate is looking for a 2 5/8" diameter, but I can't find the diameter info for our filter O-rings anywhere. Quote:
Would you go with the 40psi switch or the 60 psi switch?
__________________
#14 | |
CB7tuner Member
Quote:
Also, don't forget to upgrade to an OEM S2000 PCX oil filter! They've been proven to maintain oil pressure past 8,000 rpm. Cheap insurance.
__________________
![]() Project CB9 AeroR start-up: ////////// Slowly but surely... and gunning for that NA list! |
#15 | |
CB7tuner Member
Quote:
Do you happen to know the diameter of the O-ring on these filters? Is it 2 5/8"? I need to make sure the Canton Racing sandwich pate I am looking at can mate up to this filter properly.
__________________
#16 |
CB7tuner Member
Sorry, I haven't ordered mine yet. I would think it's the same, though, or people would report leaking, if you have an old filter laying around to measure. There's also that threaded male piece that the filter screws onto that you'll need to figure out as well. Do a search for Honda oil filter sandwich plates and they should detail the specs.
*ED. - I feel your pain, and I'm remembering now why I decided to try other tricks for the oil system over getting an Accusump. I'm getting into this search process all over again trying to help you out, and looking at all these different fitting sizes and adapters is making me feel dumb. This thread on an S2000 install was an interesting read: https://www.s2ki.com/forums/s2000-ra...nsors-1038799/ Found these parts... again, I'm feeling dumb after this, so a second opinion is strongly recommended: Going off that guy's experience I looked into Mocal. Here's their sandwich adapter w/20mm thread for oil filter compatibility, featuring two 1/2" BSP ports: http://www.improvedracing.com/oil-co...ate-p-687.html They also offer a thermostatic version of the same sandwich adapter: http://www.improvedracing.com/oil-co...ate-p-688.html And then here's a 1/2" BSPP (the second P referring to parallel threads, as opposed to Tapered; I assume that's what the Mocal port is) male to 1/2" NPT female adapter for the Accusump plumbing: https://www.amazon.com/BRASS-ADAPTER.../dp/B015ROB2NW Then of course you could get a 1/2" BSP plug if you don't need that other port, or an adaptor for a sensor or something.
__________________
![]() Project CB9 AeroR start-up: ////////// Slowly but surely... and gunning for that NA list! Last edited by CyborgGT; 11-18-2019 at 03:34 AM. |
#17 |
Gold Member
I agree on the last posted sandwich adapter. The improved racing looks nice.
Also I'm sure your tuning software can tell you your oil pressure at certain revs.. dood. are you racing without a oil pressure gauge? ![]() I reached under and took a close-up pic of mine. ![]() ![]() |
#18 | ||
CB7tuner Member
Quote:
I like the Mocal sandwich plate, especially due to its price, and the fact that you can order the correct 20mm extension screw with it. I would just get one 1/2" BSP plug and the adapter to 1/2" NPT for the Accusump. Quote:
Oh, and do you guys recommend teflon tape or paste? Canton says to use tape, but others on here in the past have recommended to use paste over the tape.
__________________
#19 |
Gold Member
Just a simple NTP adapter with tape. The oil gauge is some cheap crap i found on ebay. I assumed it's not 100% accurate as it will dip to 5 sometimes at idle and there's no adjustment for it. But all I need to know is that I have oil pressure
#20 | |
CB7tuner Member
Quote:
certain "parameters" have to be "met". If you start your car when it is freezing cold & try to go to VTEC it won't hit. (unless you are crome chipped or hondata) The ecu needs to have the engine at operating temperature. Or if you are really low on oil it won't engage either. That's why when people have a dented oil pans they have VTEC engagement issues.
__________________
Keep Pushing.. Last edited by G. Wiffington; 11-27-2019 at 01:42 PM. |
Thread Tools | |
Display Modes | Rate This Thread |
