Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive
Old 06-18-2017, 10:18 PM   #1
fleetw00d
Contributing Member
fleetw00d : 2008 Acura TSX - Another one to maintain
Daughter #3 bought this earlier this year (255,000, her only criteria was that it had to be black). She visits when it needs maintenance (edit: I exaggerate). In remarkable condition for the miles. Gotta figure out what's squeaking on the right front (only when brakes are applied). Lots of pad left, pulled the caliper and lubed the slide pins and put a little lube on the backs of the pads. It was still squeaking when she left - maybe something embedded in the pad.
2008 Acura TSX MMS by Paul Kemme, on Flickr
__________________
90 LX 4dr 5 spd 380,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
92 EX coupe auto 193,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
07 Element EX AWD 183,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts for sale or FREE http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 06-19-2017, 08:09 AM   #2
SEgirl
CB7tuner Member
SEgirl is cool... so far.
What a beautiful car! Glad she is still driving something in the Honda family.
__________________
SEgirl is offline   Reply With Quote
Old 06-19-2017, 11:09 AM   #3
Rilas
Gold Member
That really is in beautiful condition considering the mileage. Glad to see that you are treating it right, just like everything else in the family.
__________________
Old 06-19-2017, 05:38 PM   #4
Raf99
Gold Member
I love my 2004 TSX so much i wish I had an 2008. Nice car!
Old 06-19-2017, 07:09 PM   #5
'93CB7Ex
Gold Member
'93CB7Ex seems to have made some friends!
i like my 06 k24 lol
__________________
COUPE K24
'93CB7Ex is offline   Reply With Quote
Old 06-20-2017, 05:59 PM   #6
Raf99
Gold Member
I feel like the 04 was the "test bed". It has a lot of bugs, so I wish i had an 06 or an 08.
All revised to be better in later models...
- Axles wear in the boots and cause vibrations on idle
- Leaky headlights over time due to HID ballast seal
- Seat movement
- Engine performance
Old 07-14-2017, 09:23 PM   #7
fleetw00d
Contributing Member
Had to rescue this one today. Daughter called with dead battery. $140 later she's on the road again. Man, that's a tiny battery!
Old 07-22-2017, 04:33 PM   #8
dhill_cb7
CB7tuner Member
dhill_cb7 seems to have made some friends! dhill_cb7 seems to have made some friends!
photobucket ! Stinks the picture isn't working.
Ashame she only comes over when she needs something. That is how a few of friends are. I guess I shouldn't consider them friends
Pretty high mileage. How does it run otherwise?
dhill_cb7 is offline   Reply With Quote
Old 07-23-2017, 04:16 PM   #9
fleetw00d
Contributing Member
Runs fine, everything works. She's up to 260,000.
8/3/2017: Battery hold down bolts were all rusted (one broke) when I replaced the battery - installed new bolts and nuts. Pulled the right front caliper and used an 80 grit Scotchbrite disc on the faces of the pad and to take the glaze off the rotor. It was quiet on a short test drive.
9/11/2017: Did the same thing to the left front a while ago, but it was squeaking again when she came over on Sunday. She also got rear ended last week, minor dent and paint rubbing on the rear bumper. She didn't get the other driver's info; working through the local PD with a description of the vehicle.
Sometime since the last post: oil change, transmission drain and fill, coolant drain and fill. Cleaned engine compartment.
Old 03-25-2018, 03:05 PM   #10
hiptech
CB7tuner Member
hiptech seems to have made some friends! hiptech seems to have made some friends!
Purchased my 04 6-spd Navi in May of 2003 so I was one of the early adopters of the series which I can't believe will be 15 years this July! Just a little over 70k but still enjoy it very much. Raf is right about the glitches of the 04-05 and I had them all but fortunately were all handled through recalls. Since then no major problems only minor unexpected annoyances like physically broken switches that were rarely used like cruise control power and rear window switches.
But there is no denying the incremental upgrades and improvements culminating with the '08 that make it highly valued. As popular consensus goes it's always best to get the last model year of a particular generation rather than the first... since it's the recipient of all the improvements learned from previous issues...
__________________
My Collection:
93SE Sedan (Cashmere Metallic)
00EXV6 Sedan (Naples Gold)
04TSX 6-Spd Navi (Premium White Pearl)
hiptech is offline   Reply With Quote
Old 04-08-2018, 09:49 PM   #11
fleetw00d
Contributing Member
I'm not sure where she's driving this thing. Another oil change yesterday (267,000). You'd think they would put the oil filter where it doesn't drain all over an axle and lower control arm. Topped off power steering, coolant overflow, redid "Wipe New" on the left headlight (didn't properly sand it with 2000 grit the first time), rotated tires. Realized she's missing a cover underneath the engine - another item for the JY list.
Old 04-15-2018, 06:30 PM   #12
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
The 1st generation TSX is definitely my favorite. Such a classic design, and such a great car overall! That one really does look fantastic for the mileage.
A TSX was high on my list for a commuter car, though I couldn't find any that looked as nice (most with half the miles, too.)
__________________
deevergote is offline   Reply With Quote
Old 02-17-2019, 11:03 AM   #13
fleetw00d
Contributing Member
Over 275,000 miles. Had a set of Yokohama Avid Ascend GT all season tires from Tire Rack installed .
Old 02-17-2019, 11:36 AM   #14
AccordWarrior
Guy Smiley
AccordWarrior is very helpful AccordWarrior is very helpful AccordWarrior is very helpful
A good friend is an original owner of one of these. His is a 2006 with the 6MT and nav and I believe nearly 200,000.
He's been itching to buy a new car, but hasn't been able to find anything similar enough to this to replace his TSX. I always thought it was one of the sharpest designed sedans Honda ever produced, and the mid-2000's era the last time Acura was any good (TSX / TL).
AccordWarrior is offline   Reply With Quote
Old 02-21-2019, 08:23 AM   #15
Ralphie
Stalker
Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed.
I completely agree Mike. This definitely one the best looking sedans Honda ever made.
I still want one of these. Wanted one real bad for a long time.
The 2nd gen TSX is not terrible, it grew on me, but this one is great.
Ralphie is offline   Reply With Quote
Old 08-31-2019, 09:28 PM   #16
fleetw00d
Contributing Member
Now at 278,000. Brakes have been squeaking and pulsing, so today I did front pads, resurfaced rotors, rear pads and new rotors (inside of rotors were worn oddly). I hate rotor retainer screws. First one I tried to get out, I put the screwdriver in, then rapped it with a hammer to possibly free it up; the tip of screwdriver broke off in the screw! I wound up having to drill all four screws in the front out. After getting a replacement (lifetime warranty) screwdriver, I was able to get the three screws (one missing) in the rear out.
This one will likely be on the market soon. The back seat is not conducive to putting a safety seat in and out, nor is the trunk to putting a stroller in. Probably look for a roughly 2009 vintage CR-V to replace it.
Old 09-08-2019, 09:01 AM   #17
fleetw00d
Contributing Member
My daughter had a reported crank, but no start event last night. Not knowing better (I guess I didn't teach her enough about cars), she found someone to jump it and it started. Battery is at 12.5 volts this morning, cranked and started fine. I'll get to AutoZone this afternoon to borrow a scan tool.
Anybody had intermittent crank, no start problems with 2008 vintage Acura or Honda?
Edit: No codes stored according to the simple scan tool at AutoZone?
I'm accumulating more OBD2 vehicles - recommendations for a scan tool to purchase?
Edit 2: Got back from AZ, indicated tire pressure was low. RF down to high 20's. Unfortunately, the RF wheel and brake was pretty hot. Looks like I'll have to rebuild the caliper.
Old 09-08-2019, 02:45 PM   #18
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
I recommend a BT scan tool. I personally have this one: ScanTool OBDLink LX Bluetooth: Professional Grade OBD-II Automotive Scan Tool for Windows and Android - DIY Car and Truck Data and Diagnostics
https://www.amazon.com/dp/B00H9S71LW..._3NvDDb05EPFZY
I use it all the time #BMWProblems, had it for about 3 years, still going strong. I wish the live data sampling was a bit faster but other than that, awesome little device!
__________________
sonikaccord is offline   Reply With Quote
Old 09-08-2019, 02:52 PM   #19
sonikaccord
Contributing Member
Welp, I'm going against the crowd here. I was not impressed with TSX when I tested it (I think it was an 05?). Felt sterile and weak... Probably needed a kpro and/or maintenance.
Loved the styling, I still turn my head when I see one. Interior was ok, it needed a few touch ups but the design is good. What probably messed me up was that I had an Accord 6-6 which definitely skews the perception a bit as far as power... The chassis was good on the street, but I never pushed it.
__________________
Old 09-09-2019, 09:25 PM   #20
fleetw00d
Contributing Member
Had to replace the right front caliper. It was dragging; I bought a seal kit to rebuild it, but the piston was corroded pretty badly.
