It doesnt really relate to the accords, but I just want to share what I been doing. Hopefully I can get the word out and sell a few of these kits.
This is my second prototype for this headlight, but its like my 6 or 7th retrofit. These are glass lenses for the sealed beam 7x6 6054and there were a BIOTCH to open. The plastic lens opened at 275 degrees for 7 min. These ones was 375 for 20 minutes!!! The housing actually warped a little bit, which helped pry off the glue...but when it cooled down it formed back to normal.
Got some 2'' pvc pipe, you will see why later. As you can see I cut the rear of the housing out, and cut on the sides to allow the projector to sit correctly and sit lower.
Rear view
This is how it will sit. On top of that pvc im putting a ABS cover just like my first attempt. That way the projector has something to mount to. The pvc will be plastic welded to the housing.
Projector clearence, JUST enough
Here is how the PVC sits. Almost a perfect fit.
Rear view
