Im working on a 2000 accord v6 automatic. Customer complains of stalling after car has been drivin, and sitting for 20min-2 hours. When the car starts (only when the issue happends) it has a weird idle and when you step on the gas it falls on its face for the lower 2000rpms. Its like a hick-up. Feels as if there is no fuel, rpms drop to idle with foot on the gas. Sounds like its starving and misfirint.. If its hick-uping and I revv in neutral it can revv no problems. Car has no Codes.
I took readings and saw the tps (even with the foot on the pedal) went down to a idle state when this was happening.
-Confirmed that tps was reading good and working, also had a volt meter that was connected to the TPS while the issue was happening to verify that the tps wasnt just going dead.
-I recalibrated the TPS to hold .5v at idle, no change.
-I also disconnected the TPS at one point, and the stall still happend.
So.... If my scan tool is showing the tps falling flat, and my volt meter says other wise, then....communication between the tps and computer? Then why does it only do it after its driven for a while and let to sit??
Second issue, when these issues happen 90% of the time (that the car stalls) the MAP falls to a idle state.
-For the hell of it I bought a new MAP sensor, problem still there. I also cleaned the passage for the MAP.
But is that casue the engine isnt displacing any air? or is the MAP at fault?
The rest of the time the car drives fine. No issues. Owner just had the valve cover gaskets done, new gaskets and seals for the manifold, new spark plugs, timing belt water pump. THE ISSUE WAS THERE BEFORE THEY DID THE WORK.
I have a decent scantool that I can log data. I included the data, its by frames.
**Tp @9.8 and 10.2 is idle. You will notice that when the VSS is going, rpm drops to idle, TPS drops to idle. This is when its stalling**
Control Module
$0E ISO 9141-2
Live Data
DTC_CNT 0
FUELSYS1 OL
FUELSYS2 N/A
LOAD_PCT(%) 25.1
ETC(°F) 108
SHRTFT1(%) 9.4
LONGFT1(%) 7.0
MAP(inHg) 7.7
RPM(/min) 1259
VSS(mph) 0
SPARKADV(°) 11
IAT(°F) 109
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.565
SHRTFTB1S1(%) 9.4
O2B1S2(V) 1.275
SHRTFTB1S2(%) 9.4
OBD OBD2
DTC_CNT 0
FUELSYS1 OL
FUELSYS2 N/A
LOAD_PCT(%) 30.2
ETC(°F) 108
SHRTFT1(%) 9.4
LONGFT1(%) 7.0
MAP(inHg) 8.9
RPM(/min) 1065
VSS(mph) 0
SPARKADV(°) 13
IAT(°F) 108
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.505
SHRTFTB1S1(%) 9.4
O2B1S2(V) 1.275
SHRTFTB1S2(%) 9.4
OBD OBD2
DTC_CNT 0
FUELSYS1 OL
FUELSYS2 N/A
LOAD_PCT(%) 29.4
ETC(°F) 108
SHRTFT1(%) 9.4
LONGFT1(%) 7.0
MAP(inHg) 8.9
RPM(/min) 941
VSS(mph) 0
SPARKADV(°) 14
IAT(°F) 106
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.720
SHRTFTB1S1(%) 7.0
O2B1S2(V) 1.275
SHRTFTB1S2(%) 6.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 30.6
ETC(°F) 111
SHRTFT1(%) 0.8
LONGFT1(%) 7.0
MAP(inHg) 9.5
RPM(/min) 931
VSS(mph) 0
SPARKADV(°) 14
IAT(°F) 106
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.895
SHRTFTB1S1(%) -0.8
O2B1S2(V) 1.275
SHRTFTB1S2(%) -1.6
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 32.2
ETC(°F) 113
SHRTFT1(%) -3.9
LONGFT1(%) 7.0
MAP(inHg) 9.7
RPM(/min) 923
VSS(mph) 0
SPARKADV(°) 15
IAT(°F) 104
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%) -6.3
O2B1S2(V) 1.275
SHRTFTB1S2(%) -6.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 39.2
ETC(°F) 115
SHRTFT1(%) -9.4
LONGFT1(%) 7.0
MAP(inHg) 10.3
RPM(/min) 857
VSS(mph) 1
SPARKADV(°) 16
IAT(°F) 104
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-11.7
O2B1S2(V) 1.275
SHRTFTB1S2(%)-11.7
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 42.0
ETC(°F) 117
SHRTFT1(%) -14.8
LONGFT1(%) 7.0
MAP(inHg) 12.7
RPM(/min) 807
VSS(mph) 0
SPARKADV(°) 13
IAT(°F) 102
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-16.4
O2B1S2(V) 1.275
SHRTFTB1S2(%)-17.2
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 49.0
ETC(°F) 117
SHRTFT1(%) -19.5
LONGFT1(%) 7.0
MAP(inHg) 14.5
RPM(/min) 671
VSS(mph) 0
SPARKADV(°) 13
IAT(°F) 102
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-21.9
O2B1S2(V) 1.275
SHRTFTB1S2(%)-21.9
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 54.5
ETC(°F) 118
SHRTFT1(%) -25.0
LONGFT1(%) 7.0
MAP(inHg) 18.3
RPM(/min) 564
VSS(mph) 1
SPARKADV(°) 10
IAT(°F) 100
TP(%) 16.9
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%) -9.4
O2B1S2(V) 1.190
SHRTFTB1S2(%)-12.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 89.0
ETC(°F) 120
SHRTFT1(%) -27.3
LONGFT1(%) 7.0
MAP(inHg) 26.6
RPM(/min) 1088
VSS(mph) 7
SPARKADV(°) -3
IAT(°F) 99
TP(%) 27.1
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-27.3
O2B1S2(V) 0.995
SHRTFTB1S2(%)-27.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 18.8
ETC(°F) 122
SHRTFT1(%) 3.9
LONGFT1(%) 7.0
MAP(inHg) 6.5
RPM(/min) 1147
VSS(mph) 11
SPARKADV(°) 19
IAT(°F) 95
TP(%) 10.2
O2S B1S12--B2S----
O2B1S1(V) 0.585
SHRTFTB1S1(%) 1.6
O2B1S2(V) 0.800
SHRTFTB1S2(%) -3.9
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 47.5
ETC(°F) 124
SHRTFT1(%) -9.4
LONGFT1(%) 7.0
MAP(inHg) 13.9
RPM(/min) 1418
VSS(mph) 14
SPARKADV(°) 19
IAT(°F) 95
TP(%) 14.1
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-13.3
O2B1S2(V) 0.545
SHRTFTB1S2(%) -7.8
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 31.4
ETC(°F) 126
SHRTFT1(%) -8.6
LONGFT1(%) 7.0
MAP(inHg) 10.9
RPM(/min) 872
VSS(mph) 4SPARKADV(°) 12
IAT(°F) 93
TP(%) 9.8O2S B1S12--B2S----
O2B1S1(V) 0.390
SHRTFTB1S1(%) -6.3
O2B1S2(V) 0.350
SHRTFTB1S2(%) -9.4
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 56.9
ETC(°F) 127
SHRTFT1(%) -3.1
LONGFT1(%) 7.0
MAP(inHg) 15.7
RPM(/min) 1797
VSS(mph) 11
SPARKADV(°) 20
IAT(°F) 93
TP(%) 17.3
O2S B1S12--B2S----
O2B1S1(V) 1.110
SHRTFTB1S1(%) -8.6
O2B1S2(V) 0.310
SHRTFTB1S2(%) -4.7
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 20.8
ETC(°F) 129
SHRTFT1(%) -10.2
LONGFT1(%) 7.0
MAP(inHg) 9.5
RPM(/min) 1005
VSS(mph) 16
SPARKADV(°) 12
IAT(°F) 93
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.330
SHRTFTB1S1(%)-13.3
O2B1S2(V) 0.330
SHRTFTB1S2(%)-13.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 47.5
ETC(°F) 131
SHRTFT1(%) -2.3
LONGFT1(%) 7.0
MAP(inHg) 19.5
RPM(/min) 1769
VSS(mph) 10
SPARKADV(°) 20
IAT(°F) 93
TP(%) 22.0
O2S B1S12--B2S----
O2B1S1(V) 0.760
SHRTFTB1S1(%) -5.5
O2B1S2(V) 0.250
SHRTFTB1S2(%) -2.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 60.4
ETC(°F) 135
SHRTFT1(%) -2.3
LONGFT1(%) 7.0
MAP(inHg) 22.7
RPM(/min) 2004
VSS(mph) 19
SPARKADV(°) 20
IAT(°F) 91
TP(%) 26.7
O2S B1S12--B2S----
O2B1S1(V) 0.290
SHRTFTB1S1(%) 10.2
O2B1S2(V) 0.210
SHRTFTB1S2(%) 6.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 19.6
ETC(°F) 138
SHRTFT1(%) -12.5
LONGFT1(%) 7.0
MAP(inHg) 7.7
RPM(/min) 1224
VSS(mph) 22
SPARKADV(°) 12
IAT(°F) 93
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.465
SHRTFTB1S1(%) -1.6
O2B1S2(V) 0.290
SHRTFTB1S2(%) 0.8
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 34.1
ETC(°F) 140
SHRTFT1(%) 11.7
LONGFT1(%) 7.0
MAP(inHg) 12.7
RPM(/min) 1152
VSS(mph) 12
SPARKADV(°) 27
IAT(°F) 93
TP(%) 20.0
O2S B1S12--B2S----
O2B1S1(V) 0.250
SHRTFTB1S1(%) 9.4
O2B1S2(V) 0.230
SHRTFTB1S2(%) 12.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 22.4
ETC(°F) 144
SHRTFT1(%) -5.5
LONGFT1(%) 7.0
MAP(inHg) 8.0
RPM(/min) 1043
VSS(mph) 17SPARKADV(°) 11
IAT(°F) 93
O2B1S1(V) 0.390
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.270
SHRTFTB1S2(%) 1.6
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 75.7
ETC(°F) 145
SHRTFT1(%) 5.5
LONGFT1(%) 7.0
MAP(inHg) 23.9
RPM(/min) 2102
VSS(mph) 21
SPARKADV(°) 20
IAT(°F) 93
TP(%) 27.1
O2S B1S12--B2S----
O2B1S1(V) 0.425
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.700
SHRTFTB1S2(%) 5.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 18.0
ETC(°F) 149
SHRTFT1(%) 0.0
LONGFT1(%) 7.0
MAP(inHg) 5.9
RPM(/min) 1421
VSS(mph) 28
SPARKADV(°) 31
IAT(°F) 93
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.015
SHRTFTB1S1(%) -2.3
O2B1S2(V) 0.270
SHRTFTB1S2(%) -4.7
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 33.7
ETC(°F) 151
SHRTFT1(%) 0.0
LONGFT1(%) 7.0
MAP(inHg) 10.3
RPM(/min) 766
VSS(mph) 4
SPARKADV(°) 8
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.935
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.135
SHRTFTB1S2(%) 2.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 32.9
ETC(°F) 153
SHRTFT1(%) 4.7
LONGFT1(%) 7.0
MAP(inHg) 8.9
RPM(/min) 751
VSS(mph) 0
SPARKADV(°) 11
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.230
SHRTFTB1S1(%) 7.0
O2B1S2(V) 0.075
SHRTFTB1S2(%) 7.0
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°F) 154
SHRTFT1(%) 7.8
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 744
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.720
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.425
SHRTFTB1S2(%) -3.1
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°F) 158
SHRTFT1(%) 1.6
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 732
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.465
SHRTFTB1S1(%) 7.0
O2B1S2(V) 0.075
SHRTFTB1S2(%) 5.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°F) 158
SHRTFT1(%) 8.6
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 744
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 97
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.485
SHRTFTB1S1(%) 8.6
O2B1S2(V) 0.155
SHRTFTB1S2(%) 8.6
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(°F) 158
SHRTFT1(%) 10.2
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 738
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 97
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.895
SHRTFTB1S1(%) 8.6
O2B1S2(V) 0.310
SHRTFTB1S2(%) 7.8
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(°F) 160
SHRTFT1(%) 10.2
LONGFT1(%) 7.0
MAP(inHg) 8.0
RPM(/min) 737
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 97
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.780
SHRTFTB1S1(%) 8.6
O2B1S2(V) 0.230
SHRTFTB1S2(%) 7.8
OBD OBD2
Control Module
$0E ISO 9141-2
Live Data
DTC_CNT 0
FUELSYS1 OL
FUELSYS2 N/A
LOAD_PCT(%) 25.1
ETC(°F) 108
SHRTFT1(%) 9.4
LONGFT1(%) 7.0
MAP(inHg) 7.7
RPM(/min) 1259
VSS(mph) 0
SPARKADV(°) 11
IAT(°F) 109
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.565
SHRTFTB1S1(%) 9.4
O2B1S2(V) 1.275
SHRTFTB1S2(%) 9.4
OBD OBD2
DTC_CNT 0
FUELSYS1 OL
FUELSYS2 N/A
LOAD_PCT(%) 30.2
ETC(°F) 108
SHRTFT1(%) 9.4
LONGFT1(%) 7.0
MAP(inHg) 8.9
RPM(/min) 1065
VSS(mph) 0
SPARKADV(°) 13
IAT(°F) 108
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.505
SHRTFTB1S1(%) 9.4
O2B1S2(V) 1.275
SHRTFTB1S2(%) 9.4
OBD OBD2
DTC_CNT 0
FUELSYS1 OL
FUELSYS2 N/A
LOAD_PCT(%) 29.4
ETC(°F) 108
SHRTFT1(%) 9.4
LONGFT1(%) 7.0
MAP(inHg) 8.9
RPM(/min) 941
VSS(mph) 0
SPARKADV(°) 14
IAT(°F) 106
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.720
SHRTFTB1S1(%) 7.0
O2B1S2(V) 1.275
SHRTFTB1S2(%) 6.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 30.6
ETC(°F) 111
SHRTFT1(%) 0.8
LONGFT1(%) 7.0
MAP(inHg) 9.5
RPM(/min) 931
VSS(mph) 0
SPARKADV(°) 14
IAT(°F) 106
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.895
SHRTFTB1S1(%) -0.8
O2B1S2(V) 1.275
SHRTFTB1S2(%) -1.6
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 32.2
ETC(°F) 113
SHRTFT1(%) -3.9
LONGFT1(%) 7.0
MAP(inHg) 9.7
RPM(/min) 923
VSS(mph) 0
SPARKADV(°) 15
IAT(°F) 104
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%) -6.3
O2B1S2(V) 1.275
SHRTFTB1S2(%) -6.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 39.2
ETC(°F) 115
SHRTFT1(%) -9.4
LONGFT1(%) 7.0
MAP(inHg) 10.3
RPM(/min) 857
VSS(mph) 1
SPARKADV(°) 16
IAT(°F) 104
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-11.7
O2B1S2(V) 1.275
SHRTFTB1S2(%)-11.7
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 42.0
ETC(°F) 117
SHRTFT1(%) -14.8
LONGFT1(%) 7.0
MAP(inHg) 12.7
RPM(/min) 807
VSS(mph) 0
SPARKADV(°) 13
IAT(°F) 102
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-16.4
O2B1S2(V) 1.275
SHRTFTB1S2(%)-17.2
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 49.0
ETC(°F) 117
SHRTFT1(%) -19.5
LONGFT1(%) 7.0
MAP(inHg) 14.5
RPM(/min) 671
VSS(mph) 0
SPARKADV(°) 13
IAT(°F) 102
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-21.9
O2B1S2(V) 1.275
SHRTFTB1S2(%)-21.9
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 54.5
ETC(°F) 118
SHRTFT1(%) -25.0
LONGFT1(%) 7.0
MAP(inHg) 18.3
RPM(/min) 564
VSS(mph) 1
SPARKADV(°) 10
IAT(°F) 100
TP(%) 16.9
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%) -9.4
O2B1S2(V) 1.190
SHRTFTB1S2(%)-12.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 89.0
ETC(°F) 120
SHRTFT1(%) -27.3
LONGFT1(%) 7.0
MAP(inHg) 26.6
RPM(/min) 1088
VSS(mph) 7
SPARKADV(°) -3
IAT(°F) 99
TP(%) 27.1
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-27.3
O2B1S2(V) 0.995
SHRTFTB1S2(%)-27.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 18.8
ETC(°F) 122
SHRTFT1(%) 3.9
LONGFT1(%) 7.0
MAP(inHg) 6.5
RPM(/min) 1147
VSS(mph) 11
SPARKADV(°) 19
IAT(°F) 95
TP(%) 10.2
O2S B1S12--B2S----
O2B1S1(V) 0.585
SHRTFTB1S1(%) 1.6
O2B1S2(V) 0.800
SHRTFTB1S2(%) -3.9
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 47.5
ETC(°F) 124
SHRTFT1(%) -9.4
LONGFT1(%) 7.0
MAP(inHg) 13.9
RPM(/min) 1418
VSS(mph) 14
SPARKADV(°) 19
IAT(°F) 95
TP(%) 14.1
O2S B1S12--B2S----
O2B1S1(V) 1.275
SHRTFTB1S1(%)-13.3
O2B1S2(V) 0.545
SHRTFTB1S2(%) -7.8
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 31.4
ETC(°F) 126
SHRTFT1(%) -8.6
LONGFT1(%) 7.0
MAP(inHg) 10.9
RPM(/min) 872
IAT(°F) 93
O2B1S1(V) 0.390
SHRTFTB1S1(%) -6.3
O2B1S2(V) 0.350
SHRTFTB1S2(%) -9.4
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 56.9
ETC(°F) 127
SHRTFT1(%) -3.1
LONGFT1(%) 7.0
MAP(inHg) 15.7
RPM(/min) 1797
VSS(mph) 11
SPARKADV(°) 20
IAT(°F) 93
TP(%) 17.3
O2S B1S12--B2S----
O2B1S1(V) 1.110
SHRTFTB1S1(%) -8.6
O2B1S2(V) 0.310
SHRTFTB1S2(%) -4.7
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 20.8
ETC(°F) 129
SHRTFT1(%) -10.2
LONGFT1(%) 7.0
MAP(inHg) 9.5
RPM(/min) 1005
VSS(mph) 16
SPARKADV(°) 12
IAT(°F) 93
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.330
SHRTFTB1S1(%)-13.3
O2B1S2(V) 0.330
SHRTFTB1S2(%)-13.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 47.5
ETC(°F) 131
SHRTFT1(%) -2.3
LONGFT1(%) 7.0
MAP(inHg) 19.5
RPM(/min) 1769
VSS(mph) 10
SPARKADV(°) 20
IAT(°F) 93
TP(%) 22.0
O2S B1S12--B2S----
O2B1S1(V) 0.760
SHRTFTB1S1(%) -5.5
O2B1S2(V) 0.250
SHRTFTB1S2(%) -2.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 60.4
ETC(°F) 135
SHRTFT1(%) -2.3
LONGFT1(%) 7.0
MAP(inHg) 22.7
RPM(/min) 2004
VSS(mph) 19
SPARKADV(°) 20
IAT(°F) 91
TP(%) 26.7
O2S B1S12--B2S----
O2B1S1(V) 0.290
SHRTFTB1S1(%) 10.2
O2B1S2(V) 0.210
SHRTFTB1S2(%) 6.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 19.6
ETC(°F) 138
SHRTFT1(%) -12.5
LONGFT1(%) 7.0
MAP(inHg) 7.7
RPM(/min) 1224
VSS(mph) 22
SPARKADV(°) 12
IAT(°F) 93
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.465
SHRTFTB1S1(%) -1.6
O2B1S2(V) 0.290
SHRTFTB1S2(%) 0.8
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 34.1
ETC(°F) 140
SHRTFT1(%) 11.7
LONGFT1(%) 7.0
MAP(inHg) 12.7
RPM(/min) 1152
VSS(mph) 12
SPARKADV(°) 27
IAT(°F) 93
TP(%) 20.0
O2S B1S12--B2S----
O2B1S1(V) 0.250
SHRTFTB1S1(%) 9.4
O2B1S2(V) 0.230
SHRTFTB1S2(%) 12.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 22.4
ETC(°F) 144
SHRTFT1(%) -5.5
LONGFT1(%) 7.0
MAP(inHg) 8.0
RPM(/min) 1043
IAT(°F) 93
O2B1S1(V) 0.390
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.270
SHRTFTB1S2(%) 1.6
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 75.7
ETC(°F) 145
SHRTFT1(%) 5.5
LONGFT1(%) 7.0
MAP(inHg) 23.9
RPM(/min) 2102
VSS(mph) 21
SPARKADV(°) 20
IAT(°F) 93
TP(%) 27.1
O2S B1S12--B2S----
O2B1S1(V) 0.425
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.700
SHRTFTB1S2(%) 5.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 18.0
ETC(°F) 149
SHRTFT1(%) 0.0
LONGFT1(%) 7.0
MAP(inHg) 5.9
RPM(/min) 1421
VSS(mph) 28
SPARKADV(°) 31
IAT(°F) 93
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 1.015
SHRTFTB1S1(%) -2.3
O2B1S2(V) 0.270
SHRTFTB1S2(%) -4.7
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 33.7
ETC(°F) 151
SHRTFT1(%) 0.0
LONGFT1(%) 7.0
MAP(inHg) 10.3
RPM(/min) 766
VSS(mph) 4
SPARKADV(°) 8
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.935
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.135
SHRTFTB1S2(%) 2.3
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 32.9
ETC(°F) 153
SHRTFT1(%) 4.7
LONGFT1(%) 7.0
MAP(inHg) 8.9
RPM(/min) 751
VSS(mph) 0
SPARKADV(°) 11
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.230
SHRTFTB1S1(%) 7.0
O2B1S2(V) 0.075
SHRTFTB1S2(%) 7.0
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°F) 154
SHRTFT1(%) 7.8
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 744
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.720
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.425
SHRTFTB1S2(%) -3.1
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°F) 158
SHRTFT1(%) 1.6
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 732
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 95
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.465
SHRTFTB1S1(%) 7.0
O2B1S2(V) 0.075
SHRTFTB1S2(%) 5.5
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°F) 158
SHRTFT1(%) 8.6
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 744
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 97
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.485
SHRTFTB1S1(%) 8.6
O2B1S2(V) 0.155
SHRTFTB1S2(%) 8.6
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(°F) 158
SHRTFT1(%) 10.2
LONGFT1(%) 7.0
MAP(inHg) 8.3
RPM(/min) 738
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 97
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.895
SHRTFTB1S1(%) 8.6
O2B1S2(V) 0.310
SHRTFTB1S2(%) 7.8
OBD OBD2
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(°F) 160
SHRTFT1(%) 10.2
LONGFT1(%) 7.0
MAP(inHg) 8.0
RPM(/min) 737
VSS(mph) 0
SPARKADV(°) 10
IAT(°F) 97
TP(%) 9.8
O2S B1S12--B2S----
O2B1S1(V) 0.780
SHRTFTB1S1(%) 8.6
O2B1S2(V) 0.230
SHRTFTB1S2(%) 7.8
OBD OBD2
