S2000 Steering Wheel Installed!
    that wheel is so fuckin sweet!!
    fantastic job man. way to put forth the effort.
    now get to work on the DIY's for the cluster and the wheel/column.
    peace.
    Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
      I am doing a BB6 Cluster Swap for a member on here (losiracer2)
      I'll write a DIY up then
      Your man for wiring solutions!
      CB7Man's Coupe H22 Swap
      CB7Man's Sedan Resurrected From The Dead
        Originally posted by excalibur02 View Post
        great mod!
        It doesnt say but did you wire up the SRS? Does the airbag work?
        A 90 LX doesnt have SRS or ABS
        a 92-93 EX would have all features
          Oh! didnt know you had a 90 LX.. thanks for the reply tho!
            The SRS and other is possible. I had an RSX wheel in my CB for a while, but didn't like it. I used the same approach with the CD column, and while I was at it, had to do a little wiring/connector change. But everything was plug and play like stock.
              Originally posted by oneoffaccord View Post
              lol tony, cpmike didnt help me with wiring this time around. theres alot more than wiring to make it work. a s2k cluster would make it look better aswell as black/gray interior. hand off that steering wheel my way
              Hmmm, You must have been doing a lot of homework. Are you still keeping it a top secret mod?? I must say a project like that deserves to be in a magazine.
              1993 Accord EX
              2011 Subaru STi
                great mod man i hope you dont make a DIY
                UNDERGROUND SOCIETY
                NEW COUPE MEMBERS RIDE THREAD COMMING SOON
                  hmmm... i didn't realize it took so much work to make that work...
                  dang....
                  good work!
                  "Self Renewed"
                    this is amazing, i was just wondering what an s2k wheel would look like on the cb, you've inspired me!
                    1992 Accord EX MT : CB#2
                    DIY OEM amber corners w/reflectors
                      Dont?
                      It isn't a totally "safe" mod to do.
                      The steering column is supposed to collapse in a wreak....however the "extensive grinding" removes the sliding mechanism from the column.
                      This could potentually kill you.....
                      So if you do it, dont get into a wreak!
                      Heres a little mod I did for my column shafts...
                      CB Steering Wheel uo for grabs!
                      $15 shipped
                        is that off a integra?
                          Nothing of mine is from an integra
                          Except my 40/40 Brake Valve
                            sweet man. very secretative...i like
                              ICK! I can see why you didnt like it!
                              But the steering wheel looks similar to the S2000 shape
                              Same with the cruise....
                              Maybe they are interchangable?
                                Saftey
                                I guess I should address the issue of saftey
                                Whenever swapping something as important as the steering column, saftey IS # 1
                                First of all I wouldn't recommend doing this if you have the 90-91 trim bezel
                                It pushes the columnm further out and the splines actually come further out to the point of the "Saftey Bolt"
                                It wont let the steering column fall out, but...your steering splines are at the Danger zone.
                                Converting to the 92-93 trim bezel is fast, and easy.
                                No mods are required and your newly installed column is now rendered "safe"
                                Another issue is the column collapsing.
                                Incase you dont know all steering columns built after....The late 60's are supposed to collapse in a wreak where you (probally aren't wearing a seatbelt).
                                The factory mounting of the column "breaks" in a wreak and the column slides into itself, preventing you from being posibly speared.
                                The way I've mounted my column wont (probally) colapse if I were to slam into it. I will try to re-arrange the slides in order to make them slide
                                90-91 Trim Bezel installed
                                92-93 Trim Bezel
