havent really seen to many on here just wondering...
are there any f22 turbo cars on here without dsm crap on them?
member ride thread
DIVULGE MOTORSPORTS
John 10:18 "No one takes it from me, but I lay it down of my own accord. I have authority to lay it down and authority to take it up again. "Tags: None
I have one, no dsm crap unless you consider an Sabb side mount intercooler DSM.
check the sig..90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
thats good! saab is a ok hell i started with a saab t3 turbo when i first put my kit together!
member ride thread
DIVULGE MOTORSPORTS
cool u also got an 1990 accord? same here
Tell us about your car and what you have done to it....what turbo stuff you got on.. how much ya boosting??
my is an LX coupe with an F22A4 engine, had about 148K miles on it90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
ive got the following
tubular manifold
custom 3 inch downpipe
t3/t4 60-1 ball bearing turbo
tial wastgate
blitz bov
missing link
440 cc injectors
port& polish
greddy profec-eo1 boost controller
afc
and a bunch of other shit i cant remember
im running 8.5lbs on the street and have run at most 13 at the track i have 190364 miles on my car and it is NOT builtLast edited by turbo90accord; 01-30-2004, 06:07 AM.
member ride thread
DIVULGE MOTORSPORTS
wow down in the 13's that good ET
what size diameter is your intercooler piping?? aluminum or stainless steel? which front mount intercooler are you using?
Did you remove your turbo air intake/filter for the picture? or do you run without one??
did you have any check engine cel code like 12 for EGR?? you use the missing link to hide boost to the maps, People keep telling me that SAFC would hide boost from maps, any truth in that??
Oh yeah have you done anything for your ignition? MSD? external coil? colder plug? boost retard unit??
my smaller T25 come into full boost at 2200RPM, and make max power at 5700RPM, I think the T25 can product max at 14psi.
how about the t3/t4 I was thinking of upgrading to that, but don't want to lose my low-end TQ.90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
im running 3 inch all the way back to my apex n1 muffler
my intercooler piping is 50 mm before intercooler and 60mm after
i am running a apexi intercooler
i dont use a filter cause i dont have room for one
i have not touched my ignition at all other than plug wires and iridium plugs.
i dont get any cels havent gotten any in over 6 month
i have had the setup on my car for 2 and a half years now and have around 27000 miles on the setup and havent had one single problem
member ride thread
DIVULGE MOTORSPORTS
Where are you located?? Hopefully in the eastcoast
I have 2" all aluminum piping with my Side mount intercooler. My tech from local shop say it would be perfect for an T25 turbo, since it produce less cfm then the bigger turbo. My downpipe and cat back is also 2.5" . Do you guy think the piping is too small on both intercooler and exhaust?? or is the shop tech right??
Any problem running the turbo without the air filter?? any protection from dirt and oil going into the compressor housing??
I was thinking of clamping a mesh screen on the turbo air inlet and run without the air filter also. Would that be a good idea??
how much colder spark plug did you uses?? are you using anything to retard your timming at 8.5 psi?? did ya get your safc dyno tuned? if possible please post your afc value so I can compare them with my setup. I need better low end pickup..90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
Originally posted by turbo90accord
im running 8.5lbs on the street and have run at most 13 at the track i have 190364 miles on my car and it is NOT builtKnowledge is power...in EVERY sense of the word
i do run 13 psi at the track
the turbo does have a very fine wire screen over the inlet
my afc is not dyno tuned it is street tuned using a hks a/f knock amplifyer gauge and a greddy egt. i live in the mountains of colorado so my afc graphs will be of no help to you
member ride thread
DIVULGE MOTORSPORTS
I can't say whether or not he is full of crap, but since nobody else noticed this is the same guy who got his thread closed previously. http://www.cb7tuner.com/vbb/showthre...&threadid=2184
yea my thread did get closed but who cares i dont thats also the reason i havent said anything about dyno numbers on this thread nor will i say anything about horsepower on my car.
member ride thread
DIVULGE MOTORSPORTS
