EXT : 3rd Brake Light Running Light
    my 3rd brake light lense is still fine bro. ill check 2morow in the day to see is there any warpage anywhere
      Hmnmmm ...
      First off, it looks pretty cool. Tho I could see myself anoyed for about 2 secs before I figured out how it worked (from a drivers perspective).
      Well it seems like every ones main complaint is that it's too bright when dimly lit... Ya know since that plug has 2 seperate voltage feeds to that bulb, the one for the brake and the one for the running light. You can just spice in a 1 watt 1 or 2 ohm resistor into the running light wire and that would cut back the brightness. Depending on the impedance (ohm) of the resistor it will affect the brightness. Go higher for more dim. Thus you will be able to make the contrast of dim to brake ratio much more pleasing. And maybe put a stop to the negative nancy's :P
      My System
      http://www.cb7tuner.com/vbb/showthread.php?t=165155
        hey man i was gonna do that, make it a dimmer.
        and lol @ neg nancy's. i have a friend we cann him NANCY
