Wire tuck and shaving my motor bay
    here some pics of my car getting wire tucked.my boyfriend has Ben working on it for 3 days now and heres where he is at as of 30 mins ago his friend didn't help him so hes on his own kinda sucks he could use the help but he know what hes doing and just going to take longer now . but here are the pics he put the wires through the frame rail and moved my fuse box to where my jack went and the wire to move my battery to the trunk .hope you guys like pulling the motor tomorrow and welding up all the holes.
    Best of luck.
    Wire tucks prove challenging. I would be a little worried about electrical taped connections in a wire tuck.
    Solder/heat shrink is the ONLY way to do it RIGHT.
    Originally posted by wed3k
      Good luck hopefully it comes out ok. Reminds me of when I did mine.
      STANCE|WORKS
        Good Job!
        I agree with Toycar, that soldering is best- especially when extending wires for the fuse box all the way to the trunk.
        I would also suggest wrapping the wires in electrical with heat shrink to keep them from getting wet/corroding- hunting wiring shorts is a HUGE PITA.
        Nice to see another chick with a tuck.
        Project wagon! Much excite! 2018!
        That Sedan. Purchased '07-->Swap'd-->Tuck'd-->Wreck'd-->May '16
          nice can he come do mine lol cool idea on where to mount the fuse box
            These are amazing to work with and are the most reliable way i have found to join wires:
            They are solder-shrink connectors. You slide it over a join where you have wrapped the two connecting pieces of wire around each other (like two hooks then twisted), and heat it up with a heat gun. The solder in the middle melts, the outer shell shrinks, and the colored plastic glues to the wire, adding a mechanical bond to relieve stress on the joint.
            As for your tuck, it looks pretty good! I've never seen anyone put the fusebox in the trunk, seems like a good spot for it if you don't mind extending all of those wires. If I were you though, I'd put some kind of protection over the metal in the hole behind the fender, it looks a bit jagged and I'd be worried about cutting or grounding out the wires. Just some split-loom would work wonders.
              Nice. I hope you're using thick enough wires and good enough connections. It would suck to open everything again to get to "that one bad connection" somewhere. I'm sure you and/or your bf know what you're doing though, so keep up the good work..
              Btw steelbluesleepR, that looks way too easy compared to getting shrink wraps separately and soldering the wire properly with an iron. In Abiko/crimp-terminals and old school soldering we (or I) trust.
              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=197342
                that's what he is doing soldering them together heat shrinking them then raping electrical tape around that hes really good with this kind of stuff.ill post more pics soon and keep you guy updated.
                  hope you are using some good electrical tape. Super 77 made by 3m can take the heat and stand the time. Dont use the bargin stuff or anything under 3 dollars.
                  Oh and soldering is only as good as someone who knows how to solder LOL.
                  Retro!
                  Hater
                    are you painting the engine bay as well or are you just going to clean it up?
                    CALI LIFE STYLE
                    http://www.cb7tuner.com/vbb/showthread.php?t=145883
                      yes i will be painting it it will be the same color as my pink hood my boyfriend is grinding all the welds down right now and going to start puting in the bondo should be done soon also painting my motor and tranny silver
                        The way the passsenger wiring boot is sliced and wires routed upward is a runway for water. Always route wires downward first and then loop back upward to prevent filling the car with water.
                        Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
                          ya he did not think of that at that time he was in a hurry but he told me that he was going to put some stuff around the wires and where he cut it at so no moisture or water gets in.i forget what it is called i think it was like silicone or something of that sort. but it will turn out nice ill have more pics up tomorrow after it gets all welded up all the way and shaved. more to come soon
                            Good stuff! Hope to see this thing in person!
                            8 Accords so far:
                              don't worry you will my boyfriend has ben looking forward to going to this meet an seeing all of your cars he really likes your bismoto header every sints he saw it he has ben wanting one.but hes ben staying up till midnight just working on it every day non stop to get it done for me and you all to see let me know the day and time tho of the meet
