my crankshaft pulley problem please help
    my crank shaft pulley keep hitting the front traction control bar. my car is slammed real low, so im wondering is their anyway that i could fix this problem. i was thinking of heating it up alittle bit an bend it so it wont hit each other.
    by the way, its the bar the that sits right below the crank shaft pulley
    DO NOT HEAT AND/OR BEND ANY SUSPENSION COMPONENTS!!!!! You don't need to kill yourself. Heating suspension components will significantly reduce their strength and they could very likely fail on you when encountering any stresses during normal driving.
    You may have worn out motor mounts allowing the engine to hang a little low (it won't be much though). Other than that, raise your car back up some, you must be ridiculously low for the two to be rubbing.
    My Member's Ride Thread
      Not too mention that bending the bar will lead to wheel/suspension misalignment. Bending the radius rod would not be a good idea. There might be something they can do at an alignment shop. Preferably one that works regularly on dropped cars.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        I don't see being low as the cause of your problem. Follow the advice of checking your motor mounts. They might be completely worn out and falling apart, which might be causing the problem that you are having.
