clutch problem
    clutch problem
    so my clutch every time i step on it, the clutch goes all the way to the floor and stay there. so i decided to bleed the clutch but theres no bubble or air at all.
    what could i do next?
    thanks
    clutch master cylinder is probably bad. Check the shaft that connects the pedal to the cylinder for brake fluid leaks. I'd replace the master and slave. AutoZone ones apparently suck so go OEM if it's the problem. Also check clutch lines for leaks or breaks.
