engine problem
    engine problem
    my car won't start anymore, so i thought it was the starter so i changed that and when i turn the ignition the car just make a loud clicking noise. i even jump start it but wont turn on. battery is fine also. need help asap. if its engine problem then maybe just do a swap? the oil light and battery light also came on and then the car died on me.
    thanks
    I would check your battery connections and all of the grounds. How old is the battery? Did you have it tested?
    Also check to see if you can rotate the engine by hand (19mm socket on the crank bolt) remember that the engine spins counter clockwise. If the engine rotates then it is a starter/electrical issue
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
