What do engine codes mean?
    So for example, F22A1, I know F is the designation "Honda F engine" and the 22 is the displacement (2.2L), but what does the A1 mean?
    in D15B2. Its a Honda D engine with 1.5L of displacement, but there are also D15A2 engines, and D15B3 engines. And also engines like F22B1. I dont know what the last two characters represent. Can someone explain?
    Betty and Betzi died for our sins
    Its different packages, wikipedia can break them down for you.
    https://en.wikipedia.org/wiki/Honda_F_engine
      Exactly. Consider that part of the engine code as a "trim level" in many cases. The F22A1 is the base model, the F22A4 is the midrange (with 5hp more, due to the exhaust manifold), and the F22A6 is the luxury model, with 15hp over the base model (due to a number of parts.)
      To my knowledge, though, the numbers are fairly arbitrary. For example, the F22A3 (found outside the US) makes 150hp. Therefore, the higher number does not always mean the better or more powerful engine. The A/B/C/Z etc.. letter seems to designate a sub-family. For example, the CB has the F22Ax, whereas the CD has the F22Bx. The engines are related, but have some significant differences.
      What always confused me was Honda's use of the F designation for the S2000's engines, which are far more similar to the K series than any other F series. Additionally, I don't understand the DOHC versions of the F20A, F20B, F22A, and F22B. I get that the blocks are similar to the SOHC varieties, but the DOHC heads are a significant difference!
