What is/how to : adjust valves
    Hi All
    I have read before that sometimes you need to adjust your valves. These "valves" are the ones in the engine , right under the valve cover, right??
    Well, if so, how do I adjust them, and why does this reallly matter?
    Thanks in advance!
    Step 5
    http://www.cb7tuner.com/vbb/showthre...ENG%3A+tube%2A
    http://www.youtube.com/watch?v=P7wI4EtZSaA
    MRT
    sneaky motherfucker
      Thanks for the post!
        adjusting valves is one of those things that is sometimes better left to a pro
        are you ready for that sort of job
        i wound up with 2 cars that the previous owner started on a labor intensive job and just could not finish it.
        http://i220.photobucket.com/albums/d...82408002-1.jpg
          I definatley see your concerns. I am determined to understand and learn the process, but if I feel the job is too difficult, it may end up in a professional mechanic's shop.
            It's not difficult at all but very time consuming. So you need to have a full day at least to take your time and do it right. I did mine in 2 hours and I was fooling around with other stuffs. I also replace the valve cover gasket as well with the upper tube seals. So much more power and response once I was done. Of course I just also clean the EGR ports and valve as well. Keep in mind, I have never done these procedures in my life but felt really good about it afterward.
            Time is the essence to learning. Eric's the car guy has the best method and video. The other methods work but not as accurate as Eric's.
              Oh man! Thanks for bringing up the EGR.
              What is the EGR, and why is it important to clean it?
              And best of all, how do I clean the piece, and it's components?
              Links are appreciated!
