my 1993 LX doesn't blow cold air.. AT ALL. It just blows hot air no matter what. wtf
a/c not working.. just blows hot air :\?
Originally posted by JACCORD01 View PostI have no idea.. ive only started driving it a year ago, other than that it sat in my garage for years and before that it was my grandpa's.. but since ive been driving it it hasn't. Im not really sure how to run a diagnostic on this. I just want my damn thing to blow cold air again!
Originally posted by southsidecb7z View PostI dont think he would want to try and fix it if he was going to ditch the whole system...
Originally posted by southsidecb7z View PostHe dont know what he needs yet...have you checked to see if the compressor is kicking on? Checked the pressure in the system. You have to check these things, were not just gonna show up and repair it for you lol.
ill check that in a bit and report back, lol i wish you would
Well I just went through a major A/C ordeal and wasted a ton of money… so here's my advice.
- Go to a garage and get a cheapie retrofit done. Should be about $50-60 total. Talk 'em down if you can, else call another garage. The cost is marginally more than buying the DIY kit. The DIY kit I got was defective and useless.
- Have them add UV die along with the retrofit oil.
- If you have a leak, the die will tell you where. Then you get to decide whether to fix it or forget it.
- I had two leaks: a bad low-pressure valve and a pinhole in the condenser. Attempting to patch the condenser only made it worse, so now I need a new one. For now, I'm forgetting about it.
