I will be ordering another set of lenses friday and make a trip to the junk yard with my hammer. Set number two will be in the works.
EXT: Si-T Bumper lights
Originally posted by ikayto View Postwhat's in store for set number 2?
i've had good luck with flowable silicone for glass and windsields. it's at any auto parts store. if you put to much, it tends to run, but it has incredible bond strength and resistance to water.
Nic, if you don't mind me whoring your thread out, i'll post some pics of the cornerlights i did with the same method of seperation. later.Last edited by TypeG; 01-21-2009, 08:48 PM.
Originally posted by TypeG View Posti've had good luck with flowable silicone for glass and windsields. it's at any auto parts store. if you put to much, it tends to run, but it has incredible bond strength and resistance to water.
ok here is how i did mind.
the clear lenses has arrived on time.
i took no risk on the lenses,so i use the oem lens body.
the reflector inside the oem lens is clear type,but the CD's reflector is slightly shorter in width.The clip also on different side with the oem lens,so i shaved it and use super glue to hold it in the box.
glued it with glass silicone and finish!no bulging at all.
P/S:it's quite costly by using 3 set of lenses and make into 1,but the satisfactory is priceless.Last edited by Jack_lee; 01-27-2009, 05:27 AM.
Originally posted by ikayto View Postnice work jack lee, looks alot cleaner than my work lol.
good call on using oem housing.
pic on the car.
