Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 04-05-2018, 05:03 PM   #1
Yodamaster
Newcomer
Yodamaster is cool... so far.
Any source for inner wheel housings?
I'm in the process of fixing the rust on my 91' Coupe, but I'm having a problem finding a replacement inner wheel tub for both sides. The factory part is NLA unless I want to pay $300 per, which is no bueno. I already have replacement outer panels, but those are the easy part...
Am I going to have to scavenge for replacements at yards? They're probably going to have the same problem...
Yodamaster is offline   Reply With Quote
Old 04-05-2018, 08:10 PM   #2
fleetw00d
Contributing Member
If that's all the worse it is, just fashion some local patches. Otherwise, as you say, you'd need to scavenge from another car - or have someone down south here cut some out and send them to you. My 90 sedan was a lot worse; I was able to get both the outer and inner from a single car for $100 per side. The outer half of the wheel tub is part of a much larger piece. The thread below shows how I went about replacing the rusted part of mine.
http://www.cb7tuner.com/vbb/showthread.php?t=180806
__________________
90 LX 4dr 5 spd 372,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 253,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 170,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 04-22-2018, 03:17 PM   #3
yh61r
CB7tuner Member
yh61r is cool... so far.
I'm in the same boat. I'm going to weld the inside directly to the outside. In my opinion, this is much better than having two sheets on top of each other because there's no room for mud and moist to pile up and cause rust, again. Between two sheets is where rust starts, 99% of the time.
yh61r is offline   Reply With Quote
Old 05-16-2018, 06:47 PM   #4
Yodamaster
Newcomer
I decided to just wing it and fashion some patch panels myself, takes a lot of time to get them looking somewhat OEM instead of just slapping metal in. It's VERY difficult to weld in there without having the entire quarter panel off, not much room to maneuver the MIG torch. Temporarily mounted the bumper to check alignment, looks good!
Old 06-22-2018, 10:35 PM   #5
fleetw00d
Contributing Member
You're lucky you still have the mounting points there. Many times, by the time you have significant rust above the bumper, that lower area is gone and the bumper is sagging.
