Don't have a working multimeter so I just changed out the relay, didn't fix anything. The coolant is not dirty, radiator cap doesn't leak, reservoir fills when hot, both upper and lower hoses get hot (lower feels slightly cooler than upper), no white smoke from exhaust, with the heater on the temp drops drastically.
I'm letting the engine cool down right now in an attempt to bleed the system.
I plan on changing the thermostat just in case.
I don't have a heat shield but my headers are wrapped.
What should I look for next?
