this might be a noobish question, but why is this necessary to do? like what is the point of it, and what would happen if you don't do it? Thanks
SUSP : Rack and Pinion
you change it because...well it need to be changed. the boots are ripped and all the grease leaks out...and if you dont change it, over time your steering wheel will lock in place and you wont be able to turn your steering wheel at all which is bad if youre on the freeway or something
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
steering was a bit tougher...like i needed both hands to turn the steering wheel quickly...not as bad as without power steering but it was getting kinda bad...i looked underneath and notice the boot on the passenger side was torn so i replaced it.
just found out my steering rack and pinion is F*** UP bad.... BTW i dont have a power steering and i took out one of the main lines. do any of you guys think that if i change it, it will get fucked up again cuz theres no fluid in it?
oh yea how much is R/P brand new at any parts store(autozone or oriely)?
a couple of people are running new R&P without power steering and i dont think theyve had a problem...jed (ssdh22accord) is one of them...at auto zome the R&P would be about $200
i just wanted to bump this thread incase anyone else like me is having rack n pinion problems
CLICK ON SIG FOR MEMBERS RIDE
"2SIIC"
Authentic Jerseys for sale
http://www.cb7tuner.com/vbb/showthread.php?t=188314
Originally posted by arrozburneri gave up on improved steering and just went the stock way...the r&p cost me 119.00 and it took me about 6 hours i think...i could cut the time alot now though...the first time always takes longer...and i did it myself, i only needed my friend to turn the steering wheel wheni was draining the fluid other than that, i did it allGary A.K.A. Carter
[sig killed by photobucket]
at a small mom & pop auto parts store by my house...if you go to auto zone or some big place like that then it'll be 200 with lifetime warranty
i got one from a shop by my house for 85.95 but thats with trading the old one for the new one
"2SIIC"
i don thnk you have to drop the cradle to take off the rack n pinion its a simple bolt off
"2SIIC"
Is there any way to upgrade out steering rack to get a better turn ratio?
Anyone done it?
Any companies?
Probably is another DIYDEVOTE
FS: Lokuputha's Stuff
