Originally posted by pedalpusher90
View Post
Not your regular "Honda Idle"
Originally posted by reklipz View PostSounds like a faulty EACV, or a bad ECU (causing EACV to go wonky), honestly. Try disconnecting the electrical connector from the EACV and see if the crazy idle goes away? You should get a code 14 thrown the moment you do this, and the RPM should drop (from 750 RPM at idle to maybe 500-600 RPM).Originally posted by GummiegorillaDamn CBs are like a Rubix Cube sometimes !!!!
Originally posted by pedalpusher90 View PostAre you talking about the IACV? If so when I unplug it the rpm does drop to 500 rpm. Tonight it was acting normal for about an hour and other times still fluctuated
