H22 wiring
    H22 wiring
    As some of you may know, I'm dumping a JDM H22 in my 93 accord very soon. Old engine is coming out this weekend. I just ordered a helms manual but I'm anxious to get some answers now. The swap will require me to wire in the below sensors. My biggest question is, for the ones that have two or three wires, wth do I do with the extras? I'm assuming the second wire needs to be grounded to the block, but what about the third wire? I.E. vtec pressure switch has three wires. Thanks!
    Vtec solenoid
    Vtec pressure switch
    Intake air bypass (IAB)
    Knock sensor
    Evap purge solenoid
    http://www.cb7tuner.com/vbb/showthre...&threadid=5423
      As far as I know vtec pressure has only two wires, I just cut off a clip from a junk yard car to get the extra pins I needed and ran them to the ecu. You can use your f22 egr so you won't have to so any wiring for that.
        Also just saw you have an EX. Your car should already have wiring for the IAB. Just use your accord harness and you'll only have to worry about 4 wires. 1 for the vtec solenoid, 1 for the knock, and 2 for the vtec pressure switch (1 ground and 1 to the ecu).
          Coupes - Yes, almost ALL cb7 Ex's come with the F22a6 that has IAB. For some reason, my car came with an f22a1 that doesn't have IAB. My car is either from Canada or it's had it's engine replaced. The car only has 142k on it, so the engine replacement might not be as likely unless someone ran it out of oil or something.
          Also, my vtec pressure switch has three wires and the vtec solenoid has one. Now, what do I do with the remaining wire(s) on my sensors? Ground them to the block?
