No blink
    No blink
    hey everyone! to the point now i noticed today on my way to work my blinkers in my dash are not coming on. just happened today, bought a relay after i checked all the fuses and found them to be good, looking as to where this relay goes. i have pulled all the relays above the fuse box on my 92 accord, but none of them match the 3 prong relay i bought at the parts store, any ideas?
    Blinkers? like signal blinkers? Check your Hazard Connection and your Signal Switch "light/low/high/signal relay" is that stick on the left side of your steering column.
      are you talking about high beams and low beams? because they work just fine. when i turn on my left or right turn signal, there is no flashing going on in the dash, no blinking what-so-ever.
        do they work outside when you put the switch in the left or right blink position?
        Ride List
        2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
        newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
          [QUOTE=XMeCCaX;3164372]are you talking about high beams and low beams? because they work just fine. when i turn on my left or right turn signal, there is no flashing going on in the dash, no blinking what-so-ever.[/QUOTE
          If your hazard button is not connected, They don't work, So i would check that. Other thing is do you hear the ticking noise while using your turn signals?
            ok i checked and there is no signals no sound of the blinkers. when i turn on my hazards though my left turn signals blink but my right do not.
              Sounds like a fuse is blown somewhere, Look under your hood and open up the fuse box and "check all of them" After that go under the driver side and open up the left side panel and check those fuses, Make sure you read the location of the fuses. I usually check them all just to make sure.
                ok i suppose i will check again, brb
                  Check the far right fuse, It sticks out and it should be a 7.5 fuse.
                    ok problem fixed. all under the dash fuses were fine (which is literally a pain in the ass since my car sits so low). i checked the fuses under the hood and seen that the hazard fuse was blown. without much faith i replaced that and then what do you know, my turn signals now work wth?? thanx for reiterating the "keep it simple stupid" approach but is very odd to me that that was the fix. i do keep blowing condenser fan fuses, isnt that for the small fan on the radiator or no?
                      No problem.
                      I just dealt with condenser fan blowing, Check your temp coolant sensor (top radiator hose follow towards engine) that pigtail check that or make sure you don't have a short with the wire harness.
                        alright i will have to check that this weekend, thanx guys for all the help!
