Friends, I could not find a replacement engine for my f22a2 CB7, but I have found the F23a, can I install it? Is it possible? Won't be too difficult?
F22a Swap To F23a
Were you the same person who asked this on the Facebook classifieds thread?
It's possible, and quite easy to a point, but it does have some complications involving ECU compatability in an OBD1 application. The same applies for most swaps that you would do. You'll use your original harness and distributor and just add VTEC wires to the harness. You'll no longer use the CKP harness on the oil pump. You'll need either an OBD1 P0A ECU or a P28 ECU tuned for the application. Use your factory driver side mount bracket and make sure you have a header for the F22B1/2 or F23A and you're good.
That's pretty much it. Had you searched you would have found most of this out.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I plan on doing the same swap here soon! i just bought a motor from over seas and has a 1 yr unlimited mile warranty. Got it from a local shop here were i live. I was told to use the following f22 parts:
Intake manifold including throttle body, injectors the whole thing
dizzy
ps pump
alternator
post mount bracket for timing but use a f23 timing belt
and then a header off a f22B motor.
Does this all sound right?
