Correct me if I'm wrong, but doesn't that same belt drive the water pump? So do you just use a smaller belt?
Balance Shaft Seal (if you value your investment, take the time to read)
I just looked at another picture of the balance shaft belt and I guess there are two balance shafts? Although it's kinda interesting that the rear balance shaft doesn't seem to have any timing marks. Unless it's just some sort of idler pulley. So basically that belt can be removed without any adverse affects?
Originally posted by Mike1357 View PostI just looked at another picture of the balance shaft belt and I guess there are two balance shafts? Although it's kinda interesting that the rear balance shaft doesn't seem to have any timing marks. Unless it's just some sort of idler pulley. So basically that belt can be removed without any adverse affects?
You gain about 5whp by removing the belt is what I heard, which makes sense. These balance shafts weigh about 9lbs combined so that's worth the savings I think. I removed them on my DD and the vibration isn't horribly noticeable but it is there. But that's only at idle, any other speeds above 1500 RPM its not noticeable.
That's one of the sacrifices you make, but I am averaging 33~34mpg per tank so I think that the engine not having to rotate those is helping that figure.
member's ride thread
91 Accord SE 176k
