Need your help with this computer homework!!
    OK, I know that there are some people out there than can help me out. I am taking this hardware support class and I have like a 50 page multiple choice homework thing to have done by monday, and I have been working for hours and I am stuck on a few.. help me out, please!
    1) on which i/o address would you find the second ide controller in a pc-compatible system? A. 070 B. 170 C. 278 D. 378
    2) what type of problem will create an NMI type interrupt in the system? A. parity check error in dram memory b. irq conflicts c. when active io channel check from adapter in expansion slot d. over voltage of system
    3) what is the maximum speed specified by the standard infrared protocol? A. 64k b. 115k c. 128k d. 4mb
    4) what is the maximum permissible length for standard scsi daisy chain including internal cable? A 10f b. 15f c. 20f d. 25f
    5) what is the permissible length for a standard scsi cable segment? A 3f b. 6f. c. 9f d. 12f
    6) what of the following is not valid scsi connector? A. 25 pin db b. 34 pin centronics c. 50 pin centronics d. 68 pin centronics
    7) What type of error checking is associated with parity operations? A. single bit b. xor c. 8-bit d. ecc
    8) How does windows alert user infrared device is within range? A. icon in my computer b. icon in taskbar c. icon in control panel d. device window pops up
    9) How can you correct soft-memory errors? A. replace processor b. remove all ram c. replace all ram d. restart computer
    10) What are the consequences of installing a floppy cable in reverse? A. fdd stay on and erase boot record on disk b. fdd doesn’t spin c. fdd light flash and will read but not write d. fdd will work normally
    11) What command is used to restore a drives master boot record and partition information? A. a. sys c: b. mbr /renew c. fdisk /mbr d. format c:
    12) What at command is sued to reset a modem? A. atz b. atm c. atw d. att
    13) How can you correct hard-memory errors? (same choices as in 9)
    14) What processor has cache memory that operates at half core bus speed of other microprocessor sections? A. Pentium pro b. p2 c. p3 d. Celeron
    15) What processor works with 66mhz front side bus? A. p75 b. p mmx c. p3/450 d. duron/600
    16) what type of error will a memory parity error create? A. fatal exception b. nmi c. corrupt windows os file d. gpf error
    17) What should be disabled when upgrading os? A. epp and ecp b. pnp resource allocation c. bios virus detection d. ram checks
    18) What type of communication is possible with an ieee1284 parallel cable? A. half-duplex b. full-duplex c. simplex d. selectable half or full d
    If you know any answers please reply with the question # and the correct letter answer. Thank you all!
    My song of the week (or till I change it): Snow Patrol - Take Back The City
    bump...
    Can anyone help?
      If I give you the answers how will you learn anything....? Well I'll give you some help if you really need it. Number 1 can be found in windows' device manager, my secondary ide controller is i/o 0170-0177/0376-0376 so I'm gonna say b.170. Keep in mind google is your friend and don't you have an A+ book to use? Use the index and I'll bet you can find all this stuff!
        i have the A+ book with me. I have a total of 120 questions to answer. with the use of book, google, and yahoo, these are the ones that are giving me the hardest time
          1.http://members.iweb.net.au/~pstorr/p...2/ioassign.htm
          2. http://www.howell1964.freeserve.co.u...ari_hw_02d.htm
          3. http://www.microsoft.com/resources/d...g_cnd_ubui.asp
          4.http://www.seagate.com/support/kb/di...ace_cable.html
          6.http://www.scsita.org/aboutscsi/Pictures.html
          7.http://computer.howstuffworks.com/ram3.htm
          8. I'll just straight up say it shows an icon in the taskbar...
          9. Soft memory errors are caused by interference, usually from the sun. Since they do not cause any physical damage, the bit that is "flipped" will produce the correct results the next time it is written to. Therefore, all that is necessary is to do a power cycle (reboot)
          10. http://compreviews.about.com/od/tuto...IYFloppy_8.htm
          11. fdisk /mbr will rewrite a windows MBR
          12.
          The reset command sends a reset string to the modem; the string used depends on the modem type selected. For Hayes-compatible modems, this is ATZ.
          13. Celerons have always had slow bus speeds compared to the pentium line...
          14.http://www.tomshardware.com/motherbo...sspeed-01.html
          15. Parity errors will likely cause a blue screen, which is a fatal exception
          16. That's pretty old school...like 486 old my old 486's bios had that virus checking dohicky which simply prevented changes to the MBR. When you upgrade to another OS, you will more than likely be changing your MBR, so I would go with that.
          17. 1284 works in hlaf-duplex
          BTW, sorry if I insult you, but if you're going for your A+ certification, you'll need to know some of this stuff. At least a third of it is pertinent, and if you want to fix pc's you'll need to know it as you know the back of your hand. Good luck, and let me know if you still need some help. Btw.....
            the thing is, i dont need the certification. I am taking this hardware support class and my teacher is trying to get us all to take it. personally, i dont give a crap about the certification test, i just want to pass the class and get the hell out of there.
              Oh, forgot to mention, thanks for the help
                he answered 19, the answer to 17 is u disable bios virus checking when upgrading os....at least it makes sense cuz it would detect the upgrade as a virus accessing ur boot section.
                  I just want to say this thread makes my head hurt.
                  -Jay
