I also noted that if its listed on the Majestic page it is usually still available. I also agree that to verify info further, Bernardi's part page will advise what is no longer available, or available through Vintage Parts, Inc. only.
And as an fyi, regardless of description, I noted that the one you circled should be the entire kit. It appears the way Honda noted accessories was that each separate part available for a partiuclar accessory had a subletter under it. So the foglight kit is #10, and the foglight assembly left is 10B, relay 10G, etc. In this example the missing letters probably contained the foglight moldings, and switch, etc. which all have been discontinued for years.
